05-16-2017, 07:12 PM | #1 |
Pebble Pounder Join Date: Apr 2017 Location: Fresno
| Front upper shock mounts?
I just installed a 550 21t motor in stock gears and after a couple medium hard hits the front shock bolt pulled though the plastic front upper shock mount. Anyone else have this issue? There is the one forward hole that I will use, but I see this happening again. The Bomber will be driven a lot by my 3 yo son. He is fairly good at driving up routinely hits curbs at speed Anyone have an idea how to strengthen the front upper shock mount? I have seen metal versions for lowers and the rear upper but I have not been able to locate upper front metal ones :( |
05-16-2017, 07:49 PM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Front upper shock mounts?
The screw is just 2mm threads. A nice long 2mm cap screw really tightens things up, front and rear |
05-16-2017, 07:57 PM | #3 |
I use cap screws on mine, too. You may could use a washer and nut on the backside and cinch it together.
05-16-2017, 08:10 PM | #4 |
Sounds good. I'll swap out the little all thread ones with a real screw. |
05-18-2017, 02:04 PM | #5 |
This must be a fluke. I've ripped the lower rod end off of the shock shaft without hurting the upper mount. The bolts are 3mm diameter, not 2. I replaced the stock setscrews with a longer cap head bolt with a nut on the backside to make sure it wouldn't loosen up.
05-18-2017, 05:57 PM | #6 |
I get random emails from Integy for some reason. Today's had these: http://www.integy.com/st_prod.html?p...8#.WR40Q4FOnYU |
05-18-2017, 05:58 PM | #7 | |
| Re: Front upper shock mounts? Quote:
100 different mounting locations! | |
Tags |
r s |
Front upper shock mounts? - Similar Threads | ||||
Upper shock mounts | h8z2luze | Team Losi Comp Crawler | 22 | 07-28-2009 11:04 PM |
Great easy way for upper shock mounts | axelnut1 | Tamiya TLT Crawlers | 8 | 02-18-2007 06:43 PM |
upper shock mounts on SW2 | MNorby | Tamiya TLT Crawlers | 6 | 02-13-2007 11:33 AM |
