Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Moto's bomber
Old 12-03-2017, 09:23 AM   #21
Default Re: Moto's bomber
Originally Posted by Alexander_0_1 View Post
Interesting, am I looking at it from the front or back? The motor looks like it replaces the front Rx box...
I could see myself buying this...If it wasn’t 3D printed, maybe in another material, aluminum for instance, or plastic.
This is the best shapeways has to offer. It is using their new fusion printers. The quality looks great to me. I will have no fears driving the wheels off of this setup.
Sent from my SM-N920V using Tapatalk
Motorider is offline   Reply With Quote
Old 12-03-2017, 09:11 PM   #22
Originally Posted by Teng View Post
Man I am envy you have all these Top parts. I love them and yes congratulations
I had to sell a bunch of stuff to get it. I figure it's better to have a few great rigs than several ok ones.
Old 12-04-2017, 10:57 PM   #23
At the risk of what’s coming next....Is it in yet?
Alexander_0_1 is offline   Reply With Quote
Old 12-05-2017, 04:17 PM   #24
I truly wish it were. Been very busy. It will likely be late this coming weekend.
Old 12-28-2017, 09:14 PM   #25
Finally something worth updating here. Been waiting forever for parts and changes and ideas. So I ended up changing the output shaft for a longer one with a lightned mount. The shaft mounts to the gear with much heavier 3mm hardware.
I also upgraded to HR lightened hard gears. I didn't stop there. I also searched to find the lightest slipper I could find. I settled on the avid racing triad evo. I had to file the pressure plates and drill out the spur gears to get them to fit the 5 mm shaft. I'm running 48p gears now. My finished skid now sits at 190gr. It started out over 230gr before the changes.
I picked up a pair of HH puller 500 motors on the cheap. One will be going in this bomber. It weighs only 135gr. The tekin fxr will be providing the current to feed the beastly motor.
Sent from my Pixel 2 XL using Tapatalk
Old 01-02-2018, 05:48 AM   #26
Here is a direct comparison to a stock skid. The weight savings is tremendous. 141gr savings to be exact. You will notice in the pictures the difference in the elevation of the motor mounts. I found out that the standard links will not work. Gotta figure this out. I want to run titanium links to save weight. I think I will buy rods from vanquish and bend them to my liking. Undecided right now.
Old 03-15-2018, 03:50 AM   #27
Any updates?
Ltd.yfz is offline   Reply With Quote
Old 03-15-2018, 02:24 PM   #28
Y-Town Crawlers
Del Monte's Avatar
Originally Posted by rockhugger View Post
Yes it’s a skid, but it’s an anatomically correct skid. You’ll notice a handful of changes.
1 motor forward center
2 output drop due to trans being recessed
3 a dlux motor plate to get the motor low
4 upper link plates with more tuning ability
5 lower link mounting angled to match the link angle.
5 most likely flat skid profile underneath
Looks pretty good to me.
Not actually a DLUX motor plate. Designed by High Altitude performance and cut by Y-town
And yes, very much worth the effort. You'll be amazed at what the car can do with proper geometry and set up.
I'm still on my original skid after a couple of 5k races and a ton of training runs. They're surprisingly durable.
Del Monte is offline   Reply With Quote
Old 06-15-2018, 11:05 PM   #29
Is this skid still a prototype or is it for sale?
Voodoobrew is offline   Reply With Quote
Old 06-16-2018, 12:56 AM   #30
Their for sale. Get a hold of high altitude performance. I've got one for my bomber.
Old 06-20-2018, 06:40 PM   #31
I'm interested in this for a future upgrade, and I am not on FB. Is this a mostly "bolt in" upgrade? If not, what is required to add to an existing build? Specifically, suspension links and driveshafts. Lastly, is this compatible with a 2-speed and/or dig transmission?
elRayRay is offline   Reply With Quote
Old 06-21-2018, 10:36 PM   #32
From what I saw it's not a kit. You get parts from a few places like shapeways. And I don't think it's compatable with dig or 2 speed.
Old 07-16-2018, 09:41 AM   #33
I found the parts that are available on Shapeways. Where can I find the rest? Does anyone have a way besides FB to contact the maker(s)?
Moto's bomber - Similar Threads
Moto's AX-10 MotoMudder Axial AX-10 Scorpion 55 02-11-2013 11:45 AM
Moto's Wreckluse moto 1.9 Scale Rigs 11 02-19-2009 11:58 AM
