04-17-2018, 08:16 PM | #1 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
| battery tray mods?
has anyone done anything to the stock battery tray to accommodate larger batteries?
04-17-2018, 08:56 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: battery tray mods?
A soft case 3s is already plenty of power for hours or trail / crawl, how much more do you need? Sent from my Nexus 6 using Tapatalk |
04-17-2018, 10:26 PM | #3 |
I know the lil 3s batteries are enough. The problem is I have more actual 1/10 size batteries and it sure would be nice to use them without buying more batteries.
04-18-2018, 12:53 AM | #4 |
Quarry Creeper Join Date: Sep 2017 Location: UK
Run them inside on either side in parallel....mega run time ! Velcro strap them to the cage.
04-19-2018, 04:19 AM | #5 |
Seems to be a good idea I would just like to run the interior.
04-19-2018, 08:08 AM | #6 |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: battery tray mods? Not sure what that means, but if you're talking stuff like shorty packs (10th scale buggy?) simply put weatherstripping material in the box and you're golden. I make my battery boxes out of aluminum and inlay the tray with just that material. Stack the material as necessary. Hardware stores usually carry it up to 1-1/2" thick, open and closed cell foam. Just don't pack it solid, so battery heat can dissipate. Hope that helps ya out. |
04-19-2018, 05:41 PM | #7 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
5000 3s fits just fine
04-19-2018, 07:33 PM | #8 |
soft case? I have a hard case and it don't fit.
04-19-2018, 08:37 PM | #9 |
Quarry Creeper Join Date: Mar 2018 Location: Park Hills
I have a 5200mah 3s soft case and 5200mah 2s hard cases that both fit almost the same, the 3s soft is a little thicker so I had to slide the battery tray open a little for them. I did close to an hour and a half of trail/crawling(no full throttle bashing) on the 5200mah 3s and my battery was only at 3.7v per cell. |
battery tray mods? - Similar Threads | ||||
Securing a smaller battery in the stock battery tray | Skroober | Axial SCX10 II | 8 | 12-05-2017 07:15 AM |
Bomber battery tray wont fit new Lipo battery | rock1997 | Axial RR10 Bomber | 10 | 08-20-2016 10:36 AM |
What are the battery tray or door mods | mdelongpre | Axial Yeti XL | 16 | 08-17-2016 06:20 PM |
Battery tray & battery options? | Mysterious | Axial XR10 | 10 | 02-18-2012 01:13 PM |
Battery tray... | artsifrtsi | Team Losi Comp Crawler | 3 | 01-03-2010 09:55 AM |
