Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: rear axle input angle...
Old 05-11-2018, 02:42 PM   #1
Default rear axle input angle...
Gents,
Any after-market upper/lower links that correct the rear axle input angle?
Bomber kit build puts it at about -20 degrees, that can't be right.
celt is offline   Reply With Quote
Old 05-11-2018, 02:45 PM   #2
Default Re: rear axle input angle...
Mine is the same way. Thinking about trying my incsion ss yeti rear upper links. They are $12
Sent from my Moto Z (2) using Tapatalk
wcdfmt510 is offline   Reply With Quote
Old 05-11-2018, 02:59 PM   #3
Try jato rod ends to make your upper links longer
Sent from my Nexus 6 using Tapatalk
Jboucher is offline   Reply With Quote
Old 05-11-2018, 03:06 PM   #4
Ah...those look to be about perfect...thanks.
Old 05-11-2018, 03:08 PM   #5
Is that angle really an issue?
I read plenty of build threads before buying my Bomber and never heard of people having to "fix" this...
Old 05-11-2018, 03:11 PM   #6
I don't think its a issue. I think its more that people think its wrong. Here's a pic showing the axle angle.here you can see how the axle is slightly pinion down. At full suspension compresion the drive shaft is damn near level
Old 05-11-2018, 03:27 PM   #7
It is wrong, or at the very least not optimal.
Ideally the output of the gearbox and the input of the axle pinion would be in alignment no? This reduces drive line angle and therefore drive line wear. Also, that joint as it sits statically (running ride height), is nearly at the same dimension from the running surface as the lowest part of the axle ring gear housing (pumpkin) - meaning, it's the first thing a rock is going to bash into. That joint is also one of the most fragile assemblies of the entire chassis, is it not?
Doesn't matter if the drive line is level at full compression, the chassis spends little time under full compression.
If one can rotate the axle up, you get all of the benefits that I described above with what negative impact?
Old 05-11-2018, 04:24 PM   #8
Yeah I noticed this too, even after swapping to Vanquish Currie F9's.
angrchair is offline   Reply With Quote
Old 05-11-2018, 04:26 PM   #9
Radical angle also requires more power. Upper link mount locations and lengths of the links would have to be changed. Theoretically, it could always be at whatever your desired angle may be, as it cycles, just may have to be a scratch build chassis to do it. Autocad savvy folks could mock it up in 2d, run it thru the paces in 3d. I have a class 5 unlimited bug as another iron in the fab fire, a bit of an engineering nightmare to get a tiny VW style long travel beam front end to work, keeping consistent caster as it cycles about 3-1/2", so the same concept should apply here. No engineer here, but in my head, longer links and moving the pumpkin mounts up and back would change the radius points and swing of the upper arc, allowing the input angle to be more consistent. Then once the input end is up, you automatically get a lift kit because the axle rotates down at the training arms. Does that make for another can of worms?
MAC FAB is offline   Reply With Quote
Old 05-11-2018, 05:14 PM   #10
Supershafty / jec racing trailing arms are shorter by 3mm to help with the pinion angle.
Old 05-11-2018, 06:11 PM   #11
So $45 for a set of arms or $12 for longer incsion upper links
Old 05-11-2018, 06:14 PM   #12
You get the benefits of stainless arms which are stronger than the axial plastic aluminium sandwich arms
Old 05-11-2018, 06:39 PM   #13
This is what I used. A lot cheaper that anything else mentioned.
http://www.ssd-rc.com/m4-rod-end-spacers.html
FlatLander72 is offline   Reply With Quote
Old 05-11-2018, 06:48 PM   #14
It works but after 2.or 3 you will need a longer set screw as well
Old 05-11-2018, 07:32 PM   #15
Why do you think the angle is incorrect? Once completely assembled, all is fine.
calcagno45 is offline   Reply With Quote
Old 05-11-2018, 10:35 PM   #16
really long read
Driveline 101
but TLR the faster your driveshaft spins the less pinion angle you want, but at the same time you want the output shaft and pinion angles to be the same so they are close to parallel, which is what we have in the rear of the Bomber.
SHAFT RPM OPERATING ANGLE
5000 3.25°
4500 3.67°
4000 4.25°
3500 5.00°
3000 5.83°
2500 7.00°
2000 8.67°
1500 11.5°
Old 05-12-2018, 05:06 AM   #17
It could be that "wrong" is a little excessive. I'd just like to get the input on the rear axle to, at the very least, not angle down.
Plenty of suggestions here to help me do that, thanks guys.
Old 05-12-2018, 06:51 AM   #18
It only took two shims to put the pinion angle in the acceptable range.
Old 05-13-2018, 02:43 PM   #19
I just used long traxxas rod ends as mentioned earlier in the post. Works perfect!
PileDriver is offline   Reply With Quote
Old 05-13-2018, 08:00 PM   #20
I wouldn't worry about it to much unless your breaking parts as a result. Driveline angles are more specific on 1:1 stuff because it can cause stresses and vibrations that lead to premature failure and uncomfort while riding (vibes). RC's dont spend most of their life at highway speeds like what 1:1s are designed to do so as long as it isn't binding during the suspension travel your probably not going to see any issues with it.
jstein87 is offline   Reply With Quote
rear axle input angle... - Similar Threads
New axles front and rear with better pinion angle cpu77 Newbie General 2 03-16-2017 07:10 PM
stock 4 link binding problem and Drive shaft angle question, looking for your input Tire for Hire Axial SCX-10 19 09-04-2013 07:58 AM
4ws and rear axle angle? mrklaw Tamiya CR-01 2 08-02-2009 10:18 AM
VF Dig/Rear Driveline Angle Uroplatus Axial AX-10 Scorpion 22 05-07-2008 09:36 PM
