08-05-2018, 01:40 PM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
| Show us your Lights
I am looking to put some u4 style lighting on my bomber, lets see some setups with details please. Sent from my SM-G920V using Tapatalk |
08-05-2018, 01:58 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Show us your Lights
OnetoomanyRC lightbar OnetoomanyRC headlights HeyOK KoH lights in the Exo rear housing The front lights are on a HeyOK controller, on/off from my radio and powered by my 3s battery. Sent from my Nexus 6 using Tapatalk |
08-06-2018, 02:02 AM | #3 |
I'm going to be mounting GearHead RC 4" lightbars, one on my DMG aluminum roof panel with the included tubular steel lightbar guard - and another U4-style KOH lightbar facing rearward. Unfortunately I have no pics yet, because my Bomber is temporarily set up with a T-Bone Racing Delrin basher roof panel. When I fix some other issues and this Bomber gets rebuilt, that's when I'll be mounting it up. I will say that the DMG roof is a great idea if you plan on running a front roof-mounted lightbar as it's already drilled for mounting one, and the guard protects the bar. Also, the GearHead RC bars are waterproof, bright, and plug directly in the reciever - I got a splitter to power both. Here's the rear KOH light: |
08-06-2018, 09:42 AM | #4 |
Newbie Join Date: Jun 2018 Location: Las Vegas
Durok does that KOH light bar flash?
08-06-2018, 02:01 PM | #5 |
Newbie Join Date: Apr 2018 Location: Modesto
MadDogRC 4" light bar up front. Where it is mounted you need to trim the hood so it can still open. I mounted it there because I tend to crash a lot. Its protected in this spot You can also see the backside of the MadDogRC KOH light bar under the rear roof line BTW, kit shocks have been replaced with powerstrokes. |
08-06-2018, 03:50 PM | #6 |
| Re: Show us your Lights |
08-06-2018, 04:27 PM | #7 |
| Re: Show us your Lights ^^^ But, if you got a HeyOK controller, you can make any lights do practically anything... And if he doesn't already make one that suits you, contact him and he can do custom work! https://www.freewebstore.org/heyok-p...3_1588137.aspx |
08-06-2018, 06:20 PM | #8 |
08-06-2018, 06:44 PM | #9 |
The GearHeads unfortunately will not allow separating the colors in such a fashion... But I was OK with a simpler setup. I likely won't have them on any controller at all, just on all the time. I'll admit my rig isn't going to be very complex - no interior or 2 speed transmission, either. |
08-06-2018, 06:46 PM | #10 |
Well i guess I'll get one when they are back in stock. Thanks!
08-07-2018, 03:22 PM | #11 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
I wanna run the HeyOK KOH rear lights in the exo housing also. How are u guys mounting the exo rear housing to the Bomber?
08-07-2018, 04:18 PM | #12 |
I cut the sides of the exo mount until it went under the rear of the cage. Then i drilled and bolted the exo mount to the rear of the roof bracket. Sent from my Nexus 6 using Tapatalk Last edited by Jboucher; 08-07-2018 at 04:37 PM. |
08-10-2018, 06:48 PM | #13 |
08-10-2018, 08:06 PM | #14 |
They are mounted on the forward front shock bracket with a little metal bracket secured with goop glue I think i have pictures in my build thread. Edit: There you go, pictures! Last edited by Jboucher; 08-10-2018 at 08:19 PM. |
10-05-2018, 12:57 PM | #15 |
Rock Stacker Join Date: Aug 2010 Location: outside
I made this setup. The front leds fit in a holder that installs behind the front bumper. The rear lights works w my custom roof panel that include a spoiler. It’s low profile and emits a nice solid red light like newer tail lights have. If there’s any interest I could make a setup for others as well. The front lights are stupid bright on 3s. 2s was lame. It lights up the front wall on a 53ft semi trailer. Sent from my iPhone using Tapatalk |
10-05-2018, 03:38 PM | #16 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
RC4WD BD Squadrons
10-05-2018, 06:01 PM | #17 |
Rock Stacker Join Date: Dec 2012 Location: HESPERIA, SoCAL
10-05-2018, 11:15 PM | #18 |
Rock Stacker Join Date: Jul 2018 Location: Jackson
10-06-2018, 08:24 PM | #19 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I have a Onetoomanyrcs light bar and some home brew headlights made from some 12v 194 car bulbs in 3D printed housings. I'm going to print more and mount them underneath for rock lights. |
10-25-2018, 07:57 PM | #20 | |
Rock Stacker Join Date: Sep 2018 Location: cocoa
| Re: Show us your Lights Quote:
what did you use for the rear red light? looks like some sort of light tube? | |
Show us your Lights - Similar Threads | ||||
CAR SHOW/ HOT ROD SHOW this SUN 19th at FINISHLINE R/C | FinishLineRC | Colorado | 2 | 09-15-2010 03:37 PM |
Show them to me noobs, show me the Emaxxs stock, well close | Jeepernick | Newbie General | 15 | 01-11-2006 07:52 PM |
