Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Shims for rear diff?
Old 12-02-2020, 08:11 PM   #1
Default Shims for rear diff?
hi, I am trying to get some answers. I have a Bomber and I replace the locker and gears , Vanquish , for underdrive in the rear. I am having some binding , what size shims do I need to buy and where can I buy a set ? TYVM !!!
REDdawn6 is offline   Reply With Quote
Old 12-02-2020, 08:13 PM   #2
Default Re: Shims for rear diff?
need some 5mm inner diameter shims and put them on the outside of the housing right where the driveshaft mounts. i use these, been great for me. https://www.amainhobbies.com/kyosho-...caAs6rEALw_wcB
Sent from my SM-G965U using Tapatalk
midwest_rippa is offline   Reply With Quote
Old 12-02-2020, 08:22 PM   #3
You just use a couple ? Thank you for the fast reply !
Old 12-02-2020, 08:29 PM   #4
it comes with a bunch, just use as many as needed to tighten it up so the gears arent binding. i used 2 of the 0.3mm ones, but everyones situations are probably different
Old 12-02-2020, 09:11 PM   #5
So, by adding shims, the gears are shimming away from the housing, making it not tight ? Sorry, I am new to shimming. ty
Old 12-02-2020, 09:28 PM   #6
the most common reason to add shims is that the gears are not meshing properly. this is usually due to the gears being jammed into each other too close. the helical design of the teeth draws the gears toward each other. to combat this, the shims are used on the outside of the axle housing, on the pinion shaft, next to the driveshaft mounting area. this creates a pulling effect on the pinion shaft, pulling and forcing it away from the ring gear. it removes the opportunity for the pinion gear to be drawn into the ring gear, thus negating any binding. hope this helps
Shims for rear diff? - Similar Threads
Diff shims? FordFixer Axial SCX10 II 14 01-14-2019 09:24 AM
Diff shims Straxus Axial Yeti XL 2 09-17-2015 02:59 PM
Note on diff shims pro mod steve Axial Yeti XL 3 04-18-2015 08:26 PM
Diff shims!!! axman Axial Yeti XL 23 12-17-2014 07:02 PM
diff shims??? MIKE OXBIG General Crawlers 2 03-08-2006 12:51 PM
