03-07-2009, 11:50 AM | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| SwampDawgs SCX10 build
I just got myself the scx10 crawler and built it up... Chassis: Tapered steel C-channel frame Suspension/Steering: Custom panhard bar 3-link post-mount (Fr) 4-link post-mount (Rr) Traxxas stampede shocks 30w Losi 2.5" springs (Red) 2.6 Rate Servo relocated to C-frame chassis Electronics: Venom Fireball 60T Modified HPI Rx Deans & Power-connectors Drive ESC 14t limit Venom 3600mAh 7.2v cells Custom saddlepack 13AWG silicone wire Tires: Pro-line Flat Iron 1.9 Beadlock 1.9 wheels Painted locking hubs Drivetrain: Solid axle - Locked diff Single speed Transmission Telescopic drive axles Rear fuel-tank ~ Weight added (BB pellets) Last edited by SwampDawg; 03-16-2009 at 05:54 PM. |
03-09-2009, 01:46 AM | #2 |
spent sometime tonight removing that crap green off the beadlock rings, then painting the wheels black. is there a Toyota shortbox p/u hardshell body that will fit this rig? |
03-09-2009, 12:29 PM | #3 |
| Question:? This Tamiya Toyota pickup body....Would it fit my SCX10 truck? |
03-09-2009, 01:04 PM | #4 |
Quarry Creeper Join Date: Dec 2007 Location: H.B.
They do, and they look real good. There are a few guys on this forum running that set-up.. SCX10 Picture Archive - No talking Last edited by FROADER; 03-09-2009 at 01:06 PM. |
03-09-2009, 01:11 PM | #5 |
Rock Stacker Join Date: Jan 2006 Location: Willamette Valley
I'd lower that battery mount all you can. I was able to lower mine almost .5 INCH. It really helps. I like the fuel tank "look".
03-09-2009, 01:22 PM | #6 |
thanks guys, and yea...already moved the battery as the COG was far too high and kept tipping the truck. Now mount in the rear until i can afford single cells to make my own modified triple-packs on each side of the front axle. Also, looked on Ebay for this Hilux Toyota body....OUCH!! very expensive hardshell for sure. Only one dude is selling just the fr/rr shell pieces for around 60.00 right now. Hmm? is there perhaps a chaeper Toyota body that i can use for this project? again, Thanks |
03-09-2009, 01:27 PM | #7 |
Ya RPPhobby, Towerhobbies, and others sell the Hilux bodies.
03-09-2009, 01:36 PM | #8 |
thanks for the sites! RPP is frickin awesome! is there anyone that sells this body as a "whole"? |
03-09-2009, 08:21 PM | #9 |
Newbie Join Date: Jan 2009 Location: Louisville
Thats an awesome idea with the fuel tank/rx box. Looks perfect.
03-10-2009, 06:25 AM | #10 |
yea, very easy to do! just hack off the loop-piece off the rear plastic support, turn the center shock-brace support arround, and bolt the radio box onto the center brace. This was an idea from somewhere else on RCC, so i jumped right on it. Also, lastnight i ordered: ~ 12t pinion ~ 2nd Radiobox Next, another question: I have the Venom modified Fireball 60T motor.... is this worth keeping in my rig, or should i go to a lower "Turn" motor? Still having a REAL hardtime deciding on a body for this thing? -------------- Just finished sealing all my electronics off using ultra-copper gasket maker. (Radio-box & ESC) as this is a high-heat gasket maker. Also, did some soldering to some spots i thought might pose an issue later on. Current pic, with battery relocated & used electrical tape to cover that nasty venom green over. Last edited by SwampDawg; 03-10-2009 at 07:05 AM. |
03-12-2009, 09:57 PM | #11 |
| Custom Saddlepack ~ Using existing stickpack Last edited by SwampDawg; 03-15-2009 at 08:31 AM. |
03-15-2009, 07:45 AM | #12 |
| Painted locking hubs |
03-15-2009, 08:10 AM | #13 |
03-15-2009, 08:18 AM | #14 |
thanks for pointing that out, corrected. Last edited by SwampDawg; 03-15-2009 at 08:21 AM. |
03-16-2009, 10:47 PM | #15 |
| Custom front steel bush guard bumper By: SwampDawg Made this up late last night/today, using weld steel for the plates and threadrod/alloy tubing for the bars. Turned out decent, but it still needs to be cleaned up as this is just after the first fitment. |
04-09-2009, 08:07 PM | #16 |
removed the custom bumper (shown above) and got myself these Prolines instead. Also got the parts for the Yota yesterday...missing 2 parts-trees but heres the progress so far tonight. Got the body halves together,cab back & windows on aswell as mounting the shell to the chassis. Now that im missing both the "N" and "M" parts trees, i cant really go any further on this build until i recieve the rest from RPP Hobby. Another thing i bumped into was the fact i dont have any screws small enough to finish it anyhow? where are these 2x10mm screws, etc found? Last edited by SwampDawg; 04-10-2009 at 07:18 AM. |
04-13-2009, 11:55 AM | #17 |
Just started some painting of the markers and such... man, this is just too much fun! went on Google and found the 83' Tails to get this right. |
04-13-2009, 05:43 PM | #18 |
Rock Crawler Join Date: Feb 2007 Location: Simi Vly
Looks good man. |
04-13-2009, 06:58 PM | #19 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
04-13-2009, 07:32 PM | #20 |
