Thread: My scx gone super duty build
Old 02-12-2014, 05:31 AM   #1
Default My scx gone super duty build
Alrite so i know im new at this but here goes nuttin
Started with the rtr jeep rubicon scx10
Then got some new tires and beadlocks
98sporttj is offline   Reply With Quote
Old 02-12-2014, 05:42 AM   #2
Default Re: My scx gone super duty build
Mine comes today like those tires nice!
roboto65 is offline   Reply With Quote
Old 02-12-2014, 05:48 AM   #3
And then i got the ford hi lift body from a awsome guy not too far from me
The body was covered in a rattle can bed liner the prep took forever lots of wet sanding and body filler to eliminate the antenna hole and the side mount holes from the orignal mounts
While the primer was drying i decided to make the grill and bumpers look as they should
Old 02-12-2014, 05:53 AM   #4
What is your wheelbase ...my wheelbase is longer than the wheel wells on the truck body
Upgrading an R/C is a never ending process!
monstermark is offline   Reply With Quote
Old 02-12-2014, 07:13 AM   #5
Its a bit longer than the body i like where the ft wheels are but need to shorten the rear to get it right
Then i had a complex on what color to paint it i had a few different colors of red first it was a red metallic
I compared it to the trucks we have at work it was a few shades off so change of plans went with a silver base coat and a translucent red over the top
The fun dosent stop there...
Figured red alone would be kinda boring so i started masking off the truck and sprayed some semi gloss black two tone baby
Got the truck back home and decided to add a bit of detail to it
All the paint i used was testors rattle cans and a few jars to add detail havent clear coated it yet but that is testors as well.
While i was waiting for the paint to dry i figured what better time to add the headlight/ strobe kit i got at my LHS
Head lights and turns just red in the rear for the moment still have 2 white 5mm and 2 blue 3mm leds that i dont know what to do with
The tail light holders wernt on the body i had lenses but not the buckets
Good thing i had some old plastic tool holders for my snap-on pry bars hobby knife and a hand drill set to fab them up
Reassembled her last night next will be suspension mods to make the wheelbase correct
Last edited by THX_138; 03-12-2014 at 12:04 AM. Reason: All within minutes of each other
Old 02-12-2014, 07:21 AM   #6
I like the metallic. red. But the flatter red will look better roughed up.
o0wiz0o is offline   Reply With Quote
Old 02-12-2014, 07:49 AM   #7
Nice work what kind of spry did you use I'm going to paint my hard body tundra and need advice on what to use.
Luis_5.7 is offline   Reply With Quote
Old 02-12-2014, 09:30 AM   #8
That looks sick!! What did you use to paint the rear lights and the front lights?
Old 02-12-2014, 09:42 AM   #9
The lights came painted but i know testors has marker paint red and amber will have to be brushed on
awsome becareful tho the bug bites hard on modding...
to tell you the truth the reason i wanted to build one was watching the videos of project overkill and pinky on youtube.... i didnt even have one and i was hooked
that is awesome! what did the body originally come off of?
Tamiya ford hi lift
Old 02-12-2014, 09:40 PM   #10
I just finished painting mine over the weekend. Its not a hardbody, yet. But hey... I like your color choice!
Useful tip that i learned after it was to late, the first time. Use electrical tape where your going to have a hard line, like where the 2 tone meets. It will give you a much cleaner line with less "bleed"
Hulldiver is offline   Reply With Quote
Old 02-13-2014, 03:36 AM   #11
Was the first time i have ever painted a hard body still hasnt been cleared so i could repaint but i think it will stay this way for a while
What size tires are those i picked up a set of the rc 4wd baja claws but they look huge on my truck like ill need to make a lift kit just to make it look right
Old 02-18-2014, 07:18 PM   #12
Mine are the Pitbull RockBeast. I think they are 3.7"? I had the RC4WD Boggers before and they were to big. I think they are 1/10 of an inch bigger than the claws. I have 100mm shocks all around and a lift on the front on the lowest hole but, i dont run any springs on my shocks. Alot of people tell me things i could do better but it works great for me. Im not changing anything.
Old 02-18-2014, 07:54 PM   #13
The links for the Dingo are the exact size you need for that body. I had that body. It and my dingo body were interchangeable.
Just thought I'd throw that out there.
T I N Y is offline   Reply With Quote
Old 02-18-2014, 08:27 PM   #14
I'm going to do the hard body one day. I have to buy 2 though. Im going all out. I want to make a crew with a drop bed. I've got the know how, I just dont have the wifes approval to drop $100+ on a body.
Old 02-27-2014, 05:25 AM   #15
So i have a few updates for the truck. I had a lift kit on it for a day
Then that afternoon picked up a set of losi crawler shocks orange springs for the rear and chrome for the ft
Also had picked up the alum link kit for her and converted the ft to a true 4 link
Last night figured it would be a good idea to mirror the trans
Also picked up a 2s lipo and am plannin on new mount and moving the rest of the eletronics
My scx gone super duty build - Similar Threads
1.9 Ford F-350 Super Duty Crew Cab Build Travis149 General Crawlers 42 02-08-2013 08:59 PM
F-350 Super Duty Class 1 Build brazwewn 1.9 Scale Rigs 21 03-10-2012 03:39 AM
Super Rooster or Super Duty? rncbrown1999 Electronics 4 11-25-2005 09:37 PM
Super Rooster or Super Duty XR? canadianclod Electronics 16 07-12-2005 12:36 AM
