Thread: good travel shocks for 1.9er
Old 11-30-2010, 10:17 PM   #1
Default good travel shocks for 1.9er
i like the scale affect of the honcho, dont get me wrong its awesome. BUT the shocks just arent cutting it. this seems to be the shock i see alot of people working with. eventually ill be stretching it for 2.2s but for now ima keep the 1.9s
good shocks for 1.9s?
http://www.rpphobby.com/product_p/losa5082.htm
LittleDave is offline   Reply With Quote
Old 11-30-2010, 10:19 PM   #2
also does axial or anyone make a kit that switches out all the plastic parts to a metal? i just like the idea of all metal.
Old 11-30-2010, 10:22 PM   #3
Yep click
Rogue is offline   Reply With Quote
Old 11-30-2010, 10:41 PM   #4
Rebuilding the stock shocks with the aluminum parts makes a big diffrence.
http://www.rpphobby.com/product_p/ax30115.htm
LIKES2CRAWL is offline   Reply With Quote
Old 11-30-2010, 10:42 PM   #5
i knew they made the links. my fault for not being specific i meant the plastic parts mounted on the chassis. the shock hoops. skid plate. and crossmembers i know rc4wd makes rock sliders and bumpers of metal. and from a little poking around the net i can see that vanquish makes the shock hoops.
Old 11-30-2010, 10:47 PM   #6
Check out these guys seem to have a good selection of parts.
http://www.ckrccrawlers.com/axial-ra...623b1fbff3a209
Kage is offline   Reply With Quote
Old 12-01-2010, 07:30 AM   #7
I'd leave the skid plate plastic but that's just my preference as the plastic won't grab onto the rocks like aluminum will.
canadianbacon is offline   Reply With Quote
Old 12-01-2010, 08:41 AM   #8
Losi comp shocks work great.... plus they are 2.2 shocks, that way you dont need to buy new shocks when you go 2.2 with the rig
Brett B. is offline   Reply With Quote
Old 12-01-2010, 08:49 AM   #9
thats what I did.. and those shocks are great !!!!
murky123 is offline   Reply With Quote
Old 12-01-2010, 09:03 AM   #10
i run the Proline Scaler shocks with my 1.9's then switched to 2.2's and i still used the same shocks,and they work great.you dont need a lot of flex with scalers..
sloyota is offline   Reply With Quote
Old 12-02-2010, 11:17 AM   #11
i robbed the shocks from my night crawler. they work really good on 2.2 flatirons
BRASSKNUCKLES is offline   Reply With Quote
Old 12-02-2010, 11:58 AM   #12
I run my axial plastic shocks with 2-3 drops of oil in them. Just enough to lube the shaft and piston during travel.
Works alot better than having them full of oil, and will hold me over until i feel like i need new shocks.
Mega Fattie is offline   Reply With Quote
Old 12-02-2010, 12:49 PM   #13
Traxxas bigbores for the win
They are all metal and they don't leak.
Did I mention they don't leak ??
Cave Dave is offline   Reply With Quote
