01-11-2011, 06:34 PM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Alabaster
| How to get more flex
So well went in to local hobbie store today and well bought a axial scx10. I currently have a redcat and love it how it has rear steer and the awesome down and up travel. My question is how do i get the travel that my redcat has with my honcho shocks, more lift, or what im new to all of this so can somebody help me out
01-11-2011, 06:42 PM | #2 |
Pebble Pounder Join Date: May 2007 Location: Right Here
Well I got way more articulation out of mine by installing the shocks from an ax10. You could also remove the rubber bumpstops on the stock shocks for a bit more articulation. I teamed a set of droop ax10 shocks with proline 2.2 TSL SX's and it works great.
01-11-2011, 06:43 PM | #3 |
Newbie Join Date: Dec 2010 Location: follansbee
01-11-2011, 06:44 PM | #4 |
| http://www.ckrccrawlers.com/proline-...mm-p-2197.html what about these
01-11-2011, 08:44 PM | #5 |
Quarry Creeper Join Date: Oct 2010 Location: West Melbourne, Florida
I learned that the more you use it, the more the suspention gives
01-11-2011, 08:53 PM | #6 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
They kinda wear in, if you want more flex might have to go bigger than 100mm.
01-11-2011, 10:07 PM | #7 |
01-11-2011, 10:14 PM | #8 |
01-11-2011, 10:18 PM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: covina, ca
how much flex are you looking for? i have stock green springs on the front scx shocks and am running the super soft springs on the rear! this is sitting on a 5" tissue box |
01-11-2011, 10:47 PM | #10 |
okay well another thing this thing flips all the time. Do they make a wider axle to get a better stance
01-11-2011, 10:52 PM | #11 |
im looking for the articulation, flex like my redcat. I love the wide stance and everything.
01-11-2011, 11:07 PM | #12 |
Rock Stacker Join Date: Nov 2010 Location: Big Island
01-11-2011, 11:22 PM | #13 |
what about these i might just order these http://www.rcrockcrawling.com/produc...roducts_id=762 |
01-12-2011, 08:34 AM | #14 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
From my experience, and I have PLENTY, in flippin over, theres a couple things that it could be and width is only a small small part. 1) how high is your body mounted, the higher the better chance of flipping. I have mine LOW now keeping the center of gravity nice and happy 2) Where is your battery/electronics? Keep them up front and again LOW. I put my servo on the frame and dropped my battery tray down onto the crossmembers of the chassis. 3) Wheel weight. I like to run a decent amount of wheel weight, the more the better the flex but the more motor your gonna need and the more stress on parts. Keep the fronts weighted more than the back and itll climb better. I run 10oz up front and my stock Axial 27t is perfect with LiPo. 4) Tires, tires can make or break your performance. Wider tires seem to work best for me as I like em tall. Foam can also help keep you upright in a sidehill situation. 5) Shocks...believe it or not, the stock SCX10 shocks are pretty awesome. Ive swapped em out a couple times and ALWAYS go back to the stockers. Get rid of the rubber damper on the shaft while your at it. 6) Length...I like a little longer wheelbase. Go with the Honcho links or even a tad longer. I run mine around 12.5" or so. 7) Learn how to drive. This is the number one thing that will help you crawl better. It doesnt matter if you have the baddest rig on the rocks, its only as good as you are drivin it. They always say the best mod is to the nut behind the controller lol. Go have fun, everything that I said up there is either FREE or very very very cheap. Wheel weights can be fishin weights, frame servo mount using extra parts from the kit etc. The SCX10 is an amazing platform straight outta the box, so go make it work! Matt |
01-12-2011, 11:26 AM | #15 |
the thing is i know how to drive a real one so i have a 93 cherokee on 9 inch rear and high pinion 44 in front on 39.5s but what control arms do i need,tires, and how to stretch it if anybody can give me a link to where to buy these parts so i can start crwling cause last night i bent the factory plastic rear control arms and broke both drive shafts but fixed them, and im looking for like a dodge 2500 body
01-12-2011, 12:06 PM | #16 |
And another thing how many different scx10's are there i see mine the green one, then a bronco body, and a silver one like mine which one is better i see that they are the same chassis
01-13-2011, 10:37 AM | #17 |
can nobody help me
01-13-2011, 11:06 AM | #18 |
Pebble Pounder Join Date: Sep 2010 Location: Calgary
you should research a bit.
01-13-2011, 02:32 PM | #19 | |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
Google Axial SCX-10, and let us know what you find.Do your research, then ask any questions that you may have from what you find. We are here to help. | |
01-13-2011, 05:25 PM | #20 |
Well this isnt my first forum im a member of thumpertalk, caos4x4, hardlinecrawlers, r6 forum and many many more so i know how to use the search forum just the stuff i pull up isnt what im asking
