05-15-2011, 10:26 PM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: right here!
| Another torque twist question
Its seems kind of wierd but im having this horrible torque twist on my scx10. Ive had it before on my scorpion but never on my honcho. Is there any suggestions to solve this problem. Im running 4 link truss in the front and last night I found this mods to 4 link the front using the stoick servo tray seems like its no help at all. Its miserable because whenever I trail the front right side will lift and truck will tumble over. Need help guys thanks in advance. Ive searched but nothing seems to come up about scx10 its all about scorpions. |
05-16-2011, 05:44 AM | #2 |
Rock Stacker Join Date: Dec 2010 Location: tallahassee
I had the same issue my rear susp was to soft allowing the rear to squat to much. It was really bad I could hold the front right tire 2" off the ground. I had moved the shocks and shortend up the rear links when it started doing that. Have you changed anything with the susp?
05-16-2011, 06:04 AM | #3 |
MIne is worse. It will lift about 4 to 5 inches when I throttle from a stand still. I did make the rear links longer a little. I will try to get another shock to see if itll do the trick but I have to make sure im doing the right thing before I start purchasing parts again.
05-16-2011, 06:13 AM | #4 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
a few quick remedies are mirror the tranny, thicker shock oil in the corner it is twisting to along with more preload on the same shock
05-16-2011, 06:40 AM | #5 |
I cant mirror the tranny im running summit trans. Ill maybe mess around with the shocks BUT do you guys have a suggestion on which new shocks to get any setup will do for me as long as it works and not limit my articulation too much and get rid of this twist.
05-16-2011, 12:56 PM | #6 |
Rock Stacker Join Date: Oct 2005 Location: Forest Hill
It doesn't say in your post but if your battery is in the rear, try moving it to the front. It's not really a fix, more like a bandaid for a larger problem, but it will help some.
05-16-2011, 01:58 PM | #7 |
Quarry Creeper Join Date: Nov 2010 Location: weeki Wachee
gear reduction
05-16-2011, 03:47 PM | #8 | |
Any links suggestions on what gears. I was thinking get those over/underdrive gears but I dont fully understand them yet so I gotta do more reading. If you can provide me links itll help alot. | |
05-16-2011, 04:00 PM | #9 |
heres some underdrive overdrive links, you might find them cheaper elsewhere just have to look around. those are the gears you will need. http://www.tcscrawlers.com/Axial-Rac...1-p-17253.html http://www.tcscrawlers.com/Axial-Rac...2-p-17254.html some decent info here about overdrive underdrive overdrive & underdrive gears... Why? |
05-16-2011, 04:15 PM | #10 |
Quarry Creeper Join Date: Jul 2010 Location: sidney, ny
good luck finding overdrive gears and if you do let me know i need a set asap
05-20-2011, 10:32 AM | #11 |
Solved my problem guys thanks for the help. Torque twist is now gone.
