01-14-2012, 06:36 AM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
| Pinion/drive line angle ?
I just got my Honcho built last night and used a Hand Bros CMS kit and had to redo the upper link. Jut wanting to know if I have the pinion angle close enough, it is at 20° now. Thanks joe |
01-14-2012, 06:43 AM | #2 |
Rock Stacker Join Date: Jan 2012 Location: SK, Canada
| Re: Pinion/drive line angle ?
Keep in mind, when rotating the the pinion angle, you're going to throw off the caster. This is coming from true automotive experience, so I have no idea if it'll actually affect our R/C's, but I was looking at doing this to mine last night and thought of this issue. |
01-14-2012, 07:29 AM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: Hughson, CA
Sniper 101 is right. Just make sure your knuckles don't start to point down or your steering will suffer a bit. You could also get some clockable c-hubs to help. From the pic it doesn't look to bad.
01-14-2012, 07:40 AM | #4 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
From the pictures it looks like you might already be going into the negatives on your caster, not sure though. I wouldn't worry too much about your pinion angle, unless those CVs are sensitive to the stock angles.
01-14-2012, 08:19 AM | #5 |
Angle wont hut the MIP's and I can take some of the shim out to reduce the angle.
01-14-2012, 08:46 AM | #6 |
Rock Crawler Join Date: Nov 2009 Location: poteau
personally i think you got it about right. i like to keep the driveshaft at or slightly above the suspension links. this helps for clearance, and there's nothing worse than your driveshaft sitting on a rock and your links above it! soon as you hit the gas the driveshaft will spin the rig sideways! if your steering is suffering any, just spend the $30 and get some axial clockable c hubs to bring a little caster back in.
01-14-2012, 09:59 AM | #7 |
Looks like about right, another thing to watch is the panhard link. The more you clock your axle, the more panhard link rubs on the axle mount.
01-14-2012, 10:44 AM | #8 |
Thanks Guys, I took a 2mm spacer outta the upper link and it dropped the driveshaft down below the lowers, gonna put it back |
Pinion/drive line angle ? - Similar Threads | ||||
Drive shaft angle | demonoid369 | General Crawlers | 5 | 04-09-2011 07:14 AM |
pinion angle freaked out | SinCity | Axial SCX-10 | 6 | 10-29-2010 07:59 AM |
honcho pinion angle | stick-boy-rick | Axial SCX-10 | 2 | 07-10-2010 09:32 PM |
pinion angle help | slowride1 | Losi Mini-Rock Crawler | 4 | 09-27-2009 11:16 AM |
pinion angle?? | solomon7 | HPI Wheely King | 8 | 07-19-2007 06:42 PM |
