01-16-2012, 12:30 PM | #1 |
Rock Stacker Join Date: Sep 2010 Location: Medway
| Traxxas 1/16 center driveshafts
I was looking around ebay for cheap traxxas driveshafts since i've read they are stonger than stock scx10s (I have now converted mine to a dual motor EVX-2 7 cell powered rig and I've blown up the rear driveshaft 4 times now) So when I was looking I saw the 1/16 scale center driveshaft. I wondered if anybody knows if its the same size as the diffs and trans.
01-16-2012, 12:34 PM | #2 |
| Re: Traxxas 1/16 center driveshafts
These will go right on your metal Axial yokes: TowerHobbies.com | 1953 Traxxas Long Truck 1/2 Shaft Pro Pak (6) And these are the Traxxas metal yokes which are basically the same as the Axial ones: http://www3.towerhobbies.com/cgi-bin...?&I=LXJG59&P=Z |
01-16-2012, 12:42 PM | #3 |
| Re: Traxxas 1/16 center driveshafts |
01-16-2012, 01:53 PM | #4 | |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
| Re: Traxxas 1/16 center driveshafts Quote: Here are the parts I ordered (The spur gear cover is not required obviously): All you have to do is trim the shafts to length, and run a drill bit in the end of the yokes to make the inside round to match the Axial parts, I used a 3/16" bit as I did not have a metric 5mm bit (The Traxxas parts have flat spots where the hole goes through the shaft. You also have to change the spur gear because it was slightly touches. All details in my SCX10 thread link in my sig. And also, don't bother with the TRX 1/16 shafts. Last edited by NFA Fabrication; 01-16-2012 at 02:18 PM. | |
01-16-2012, 06:23 PM | #5 |
Thanks for the links guys. I guess Ill be the guinea pig for this then. I already knew about the other traxxas shaft mods but I was curious if anybody has done this one. I'll let you know how it turns out
01-16-2012, 08:01 PM | #6 | |
Rock Crawler Join Date: Apr 2009 Location: Pa
01-16-2012, 08:22 PM | #7 |
This is what the 1/16 shafts look like They are $6 shipped |
01-22-2012, 02:35 PM | #8 |
So I got them and they look much bigger in the pictures. They are too small and dont articulate enough either
01-22-2012, 04:11 PM | #9 | |
Edit: And to be fair, at the time that thread was made, the option I chose was not available parts wise. But with the parts available today, why would you go with that method? Last edited by NFA Fabrication; 01-22-2012 at 04:16 PM. | |
Traxxas 1/16 center driveshafts - Similar Threads | ||||
LNC center driveshafts on LCC? | aconsola | Team Losi Comp Crawler | 3 | 05-12-2010 11:14 AM |
center driveshafts | boostedg60rado | Axial AX-10 Scorpion | 30 | 03-21-2010 05:55 PM |
? about center driveshafts | rider12693 | Team Losi Comp Crawler | 4 | 01-05-2010 03:25 PM |
3 Racing or MIP Center Driveshafts | Paul97 | Losi Mini-Rock Crawler | 7 | 11-27-2009 11:57 PM |
