02-04-2012, 02:46 PM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: milford
| where do people buy the electronics boxs?
Ive seen a few people buy small plastic boxes and mount them on either side of the trans on the rails. What do u use and where do u get them from? I went to micheals, and another craft store but couldnt find them. If u have pics, could u post them? thanks
02-04-2012, 02:47 PM | #2 |
Jeep whore Join Date: Aug 2008 Location: Florida
| Re: where do people buy the electronics boxs?
radio shack.
02-04-2012, 02:53 PM | #3 |
damn...i dont have one of those near me, ill have to look and see if i can order them online
02-04-2012, 03:01 PM | #4 |
Quarry Creeper Join Date: Sep 2008 Location: Fab Shop
| Re: where do people buy the electronics boxs? |
02-04-2012, 03:07 PM | #5 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
An alternative is a box that a servo came in ie. hitec, savox, etc.
02-04-2012, 03:20 PM | #6 |
how do u secure it? just screw it thru the bottom?
02-04-2012, 03:28 PM | #7 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
use the screws that hold the rock rails to hold them down thats how i have mine held down
02-04-2012, 03:28 PM | #8 |
Screw, Shoogoo, servo tape, whatever works for your application.
02-04-2012, 03:35 PM | #9 |
k, Ill order them up and give it try. Anyone have pics of setups with the boxes?
02-04-2012, 06:32 PM | #10 |
Search around, there plenty of pics. Look through the different scale section's pics.
02-04-2012, 06:43 PM | #11 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
I bought mine at " The Source" it's the Canadian equivalent to radio shack.. The stores look identical.. I know you can order online as well.. I make a plate from aluminum and screw it to the rock rails.. Then apply Velcro to the plate and the project box. Holds really well and make working on the truck a breeze when you can remove the electronics in 30 seconds. Sent from my highly abused iPhone using Tapatalk |
02-04-2012, 09:13 PM | #12 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Here's how I used mine. They were attached with servo tape but that started to give up after a few trips, our trips are usually about 4 hours though. But I just put a zip tie on and they never went anywhere. You have to cut a notch for you wires to run through but they work well. I do notice the box with the ESC does get pretty warm though. |
02-05-2012, 03:17 AM | #13 |
Quarry Creeper Join Date: Nov 2008 Location: London UK
You could use a waterproof food container, I wouldn't use anything else now. |
02-05-2012, 06:37 AM | #14 |
Quarry Creeper Join Date: Sep 2010 Location: Perth Australia
02-05-2012, 05:54 PM | #15 |
02-05-2012, 10:10 PM | #16 |
Pebble Pounder Join Date: Dec 2005 Location: W. Richland
I used the box that my Savox servo came in. I had to cut a half inch out of the center section and then put the box back together to get it to fit where I wanted it to fit. I then coated it in liquid electrical tape. Its water tight after you close it up and silicone it. It works, but its not as pretty as those boxes every one uses. If you have a servo box and the liquid electrical tape, then its a nice free option. If you have to buy the liquid electrical tape or silicone, then buy the box instead because having to either one or both (silicone and liquid electrical tape) will put you over the cost of one of those boxes easily. If I would have known how much those boxes cost and where to find them, then I just would have bought a couple. |
02-10-2012, 01:34 AM | #17 |
RCC Addict Join Date: Mar 2009 Location: Chilton
Here is a link to a thread I started for pics of different setups with electronics and most have the boxes. SCX10 electronics setup |
03-15-2012, 11:13 AM | #18 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
i just bought 2 of this,works great on my honcho.but i need 3 more.does anyone knows where to buy to be shipped to EU?
03-15-2012, 11:37 AM | #19 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
I don't get it... why would you box your stuff if it's not for waterproofing? all it does is make things more difficult to work on, and give your esc less airflow, potentially causing heat problems.
03-15-2012, 11:55 AM | #20 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
what's not to get? protection/waterproofing is really the only reason to put the electronics inside, because as you've stated there are some downsides. it's also a much cleaner alternative to balloons and other devices when you're trying to fit your stuff into an already cramped space. those tupperware/food container setups seem nice and roomy if you have space for them in your rig. I used 2 of the larger 4"x2"x1" boxes so i could fit a switch on the end of each one (power and lights). ALSO, remember to buy a couple 2-3" servo extension wires and LED extensions before you start installing your electronics into them. will make life much easier should you need to unplug something for whatever reason |
where do people buy the electronics boxs? - Similar Threads | ||||
Want To Buy AX10. What Does It Come With? (Electronics) | NFA Fabrication | Axial AX-10 Scorpion | 3 | 12-16-2011 08:28 PM |
Where do you buy your electronics? | flowingmotion | Electronics | 4 | 04-06-2010 10:59 AM |
Best places to buy electronics | speed6 | Newbie General | 5 | 11-05-2009 09:36 AM |
Seriously... they expect people to buy this | soundcolor | Chit Chat | 13 | 05-29-2009 03:31 PM |
where to buy electronics??? | guahan | Electronics | 5 | 04-18-2007 12:05 AM |
