02-10-2012, 03:19 PM | #1 |
Newbie Join Date: Jan 2012 Location: Bryant
| Flat Irons on the Trail Honcho
Do these tires perform well on the trail as well as rocks? Any info appreciated!
02-10-2012, 03:29 PM | #2 |
Pebble Pounder Join Date: Dec 2010 Location: Bay Area
| Re: Flat Irons on the Trail Honcho
Not really. They don't have a whole lot of grip.
02-10-2012, 03:47 PM | #3 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Not true, you obviously havn't used a set to point that they break in. Once they break in they're great. Also try searching. Theres hundreds of threads on this exact subject.
02-10-2012, 04:28 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Hughson, CA
| Re: Flat Irons on the Trail Honcho |
02-10-2012, 04:30 PM | #5 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
They actually work very well for a kit tire. Compared to many tires, they are very good as far as grip goes. That is when comparing just traction and not the benefit of a larger size tire (clearance). They are very good on the type of rock around here and not bad in mud. I run more muddy trails then rock so I use something different. I used a set (stock kit tires) one day when a newer set of other brand tires were not working too well and they walked all of the obstacles that were frustrating me. I was semi shocked by that. It was in comparison to a type of RC4WD tires that were very popular about a year ago. The Flat Irons have much more side tread and a softer foam and therefore worked better in those conditions that day. There can be endless tuning options to help any tire work better. Different foam, set ups, venting of tires, weighting, etc. But out of the box on unvented wheels, the Flat Irons work very well. The main thing for changing them is looks or just needing a much different size tire. You will not greatly change performance by changing them. With that being said, the new(er) PitBulls in 1.9, I have not tried. And I have not heard anything but exceptional about them in any condition. They are close to Flat Iron size (but are larger) but seem to be the best performing (overall) tire in 1.9 size. The Flat Irons look good and work very well compared to many others so changing them should not be a priority unless size or looks is the most important thing to you. |
02-10-2012, 05:06 PM | #6 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
Once they're broken in they're great, I still have my set when I got my Dingo (now H2) a few years ago. In light-medium mud they're pretty good, and most rocks they seem to grab well enough to let you get up. Also, they still look awesome.
02-10-2012, 05:16 PM | #7 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
Get them broken in, use enough weight to make them flex, and remove every second small lug on the inside edge and they work as well or better then all but the top-end super-sticky tires.
02-10-2012, 07:08 PM | #8 |
Rock Stacker Join Date: Jan 2007 Location: Plattsburgh
I never had an issue with mine but I dont comp just play at home |
02-10-2012, 07:16 PM | #9 |
Great input, and guys. Thanks!
02-10-2012, 10:33 PM | #10 | |
| Re: Flat Irons on the Trail Honcho Quote:
02-10-2012, 11:00 PM | #11 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Flat Irons do pretty well. I had a lot of hours on mine and they held up really good. I had them on the stock beadlocks, wheels vented and 4oz fr and 2oz rr of lead in each. They'll work.. I upgraded because I wanted a bit larger tire but if I was going to do something that was going to tear up tires I'd throw them back on and be happy. |
Flat Irons on the Trail Honcho - Similar Threads | ||||
reducing 1.9 flat-irons to 1.55 flat-irons: questions for you experts | heinie_21 | Tires and Wheels | 12 | 02-02-2012 10:47 PM |
flat spotted proline flat irons? | brianw | Newbie General | 4 | 02-12-2010 12:50 PM |
