02-12-2012, 12:47 PM | #1 |
Newbie Join Date: Aug 2008 Location: Indy
| What system to use
Just built my dingo now I cant decide between a vxl system or a new 4 pole castle sidewinder sct system
02-12-2012, 08:29 PM | #2 |
Pebble Pounder Join Date: Feb 2011 Location: Knoxville
I have the sct in mine now, I have only tested it out in the yard so far but it seems smooth enough for some slow stuff still. 17/89 gearing 2s --- I am here: http://maps.google.com/maps?ll=35.918235,-83.809535 |
02-12-2012, 08:51 PM | #3 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
| Re: What system to use
I just built my Dingo kit a few days ago, I swapped in the running gear from my Slash CC Sidewinder ESC w/castle link , VXL Motor , Spektrum DX3E TX , Spektrum 2.4GHZ RX, and a Hitec 465MG Servo, On 2s Lipo. It has a great bit of wheel speed, But I need to hook up my Castle Link and set the Drag Brake, and Throttle/Punch Curve. Hopefully that will take care of the low speed shudder. I may get a BL crawler motor for my Dingo if the Castle link doesn't help my shudder at low speed/ throttle imput If you do go with the VXL the Upper Suspension Link will be very close to the motor. Last edited by Tom95YJ; 02-12-2012 at 09:01 PM. |
02-12-2012, 09:25 PM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: here
You may want to look into something sensored. The low speed stutter is cogging and I don't think adjusting the drag brake will fix it. I have heard people saying the 4 pole motors have a lot less stutter. I'm running an MMP with a Losi 21.5T motor and I think it's an awesome combo. Great speed and great slow speed control.
02-12-2012, 10:15 PM | #5 |
I'm going to try my xl5 and titan out of my stampede first and see how it is then I will probably buy the sidewinder sct system I just need to figure out how to make the sidewinder waterproof
02-12-2012, 10:21 PM | #6 |
Open the case. Use clear silicone (so you can still see the LEDs) and coat everything. Make sure you use a small tip and try to get a good seal between the board and the heat sink. Coat everything enough that when you close the case back up it oozes out any openings, then just wipe the excess off. I did that with the MMP on my Slash 4x4 and it worked great. I haven't submerged it yet but I have gone through nasty puddles at top speed.
02-13-2012, 09:47 AM | #7 | |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
| Re: What system to use Quote:
02-13-2012, 04:07 PM | #8 |
Thanks for the info on water proofing anybody know what gearing I should use for the 12t titan all I have is 14/87 pinion and spur that it came with I want to be able to run fast thru the mud and dirt I'm not looking to rock crawl with it
02-13-2012, 04:38 PM | #9 |
Pebble Pounder Join Date: Oct 2008 Location: Oshawa, Ontario Canada
I run a Novak Goat 3S with a Tekin 35 turn brushed motor on 3S lipo in mine 16/ 87 gearing and I love it good wheel speed, lots of low end torque. I have everything in this nice little box from Radio Shack, when I'm done a day of wheel'n I just hit the car wash or use the garden hose never had any water get in... |
02-13-2012, 06:06 PM | #10 |
If you're gonna go brushless, go sensored. No matter how much tinkering you wanna do, trying to gear/program the cogging out just ain't gonna happen. The castle 14xx 4pole are awesome otherwise. Cheap sensored brushless cogs a lot less than expensive sensorless, torque and efficiency on the other hand... |
02-13-2012, 07:27 PM | #11 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
Silicone is not a good idea, it actually attracts and stores moisture, makes me laugh when I see silicone around the back window of an old car.......they are just making it rust faster |
02-13-2012, 09:26 PM | #12 |
It's not that it attracts moisture, its the acid in the silicone that reacts with the steel. If it held moisture people wouldn't use it for caulking or building aquariums. The other thing is I bet most those people don't do the extra work to make sure it's sealed right. If they had just a little bit of rust and didn't remove it, it's going to get much worse.
02-16-2012, 04:26 AM | #13 | |
--- I am here: http://maps.google.com/maps?ll=35.917984,-83.809391 | |
What system to use - Similar Threads | ||||
RC4WD LED Light system "The Scale Lightning System (SLS) " | 4x4Crawler4LIFE | Electronics | 24 | 12-13-2012 05:38 PM |
VF/DNA DIG system for AX10 - where can I buy this system????? | DK Driver | Axial AX-10 Scorpion | 2 | 09-07-2008 04:24 PM |
