02-21-2012, 04:01 PM | #1 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| what is the size and thread pitch for screw through pins to use on MIP08101?
I want to upgrade the outdrives in the transmission of my Honcho with these (AX30435): Axial Steel Outdrive Shaft Set (2pcs) They have the pin through design. I want to also install MIP's AX10 no dig driveshafts (MIP08101): MIP C-Drive Spline Set for Axial AX10 Scorpion (2) What is the size and thread pitch for the pin through, instead of the set screws, to mount the parts mentioned above? Will these screw pins work? TowerHobbies.com | 5189 Traxxas Screw Pins 4x13mm w/Threadlock (4) If not, what part # screw through pins should I use, taking into account the size and thread pitch on the MIP C-Drive spline set for the AX-10? |
02-21-2012, 04:58 PM | #2 |
Rock Stacker Join Date: Feb 2009 Location: California
| Re: what is the size and thread pitch for screw through pins to use on MIP08101?
Those may work, but I know for sure that these will work. TowerHobbies.com | 5145 Traxxas Screw Pin 4x15mm Revo (6) The ones your looking at may be a tad bit too short. |
what is the size and thread pitch for screw through pins to use on MIP08101? - Similar Threads | ||||
stock pinion pitch size | waffelhauz | Losi Micro-Rock Crawler | 1 | 05-14-2011 08:43 AM |
Yoke pins / screw pins | cyberdog | General Crawlers | 2 | 05-27-2009 03:06 AM |
stock tlt screw thread pitch | obijuan | Newbie General | 1 | 08-03-2007 06:06 PM |
Missing screw on shoulder arm (King Pins) | ECAMERON87 | Tamiya TLT Crawlers | 3 | 05-11-2005 12:01 PM |
