02-25-2012, 03:39 PM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: tampabay
| 20T Wraith motor in a Honcho
This will get the wheels spinning |
02-25-2012, 04:21 PM | #2 |
Rock Stacker Join Date: Jan 2011 Location: Oak View,Southern California, Ventura County~805~
| Re: 20T Wraith motor in a Honcho
if your running stock drive shafts your gonna break em in no time, was runnin that motor on a 2c 5000mah battery and smoked the front driveline, fun speed though, for a lil bit |
02-25-2012, 06:16 PM | #3 |
| Re: 20T Wraith motor in a Honcho Got the motor off of ebay for 12.00 going to put the 27 back in. Just having fum
02-27-2012, 11:09 AM | #4 |
Pebble Pounder Join Date: Feb 2012 Location: Freakville
Look up Squirreled on youtube. He has a video on how to upgrade the drive line for 2 bucks. Ive been running my Wraith on Brushless and havent had an issue with the stock axles.
06-23-2012, 02:44 AM | #5 |
Newbie Join Date: Jun 2012 Location: Honolulu
New here guys and fairly new to the crawler community. I'm looking into putting the Axial 20T motor in my SCX10. Any other problems aside from the driveshafts? Will the stock transmission, slipper clutch and axle gears handle the increased power? Thanks |
06-23-2012, 04:20 AM | #6 |
RCC Addict Join Date: Jul 2011 Location: Orlando
First off everything on the SCX10 is fine to install the 20t...... at least for a short period of time. The only real issue like others have said, when you get into real wheel speed and power the drivelines (driveshafts) begine to fail. They twist, torque or snap under greater power. I would just plan on ordering MIPs and be done with it no matter what type of power you put down. I have run everything on my Rig with a ton of power and never worried about the driveshafts. But one thing to remember, the driveshafts are the first line of defense when something goes wrong. They will break or snap when it has binded up or if there is some unknown issue. Upgrading your drive shaft will now make the next spot be the breaking point. So upgrading your trans would def be a GREAT idea. The stock axial outdrives the connect to the driveshafts are not all that strong. Robinson Racing has a full trans upgrade kit and then your trans would be somewhat bulletproof. Robinson Racing Outdrive Diff Lock Gear AX10/SCX10 Robinson Racing Hard Steel Idler Gear AX10/SCX10 Hot Racing Axial SCX10 AX10 Wraith hard steel center gears set MIP Spline Set Center CVD Kit (SCX10) |
06-25-2012, 01:58 PM | #7 |
Thanks brother! I have the MIPs ordered from Tower and will most likely get the tranny you recommended. Much appreciated. |
06-30-2012, 05:22 PM | #8 |
Still have the 20t Wraith motor in the Honcho with no problems to date |
06-30-2012, 06:24 PM | #9 |
Newbie Join Date: Jan 2012 Location: planet earth drr
i have ran a 20t wraith motor in my somewhat stock honcho. i was running a 2 cell lipo snapped my drivelines front and rear. i am a little hard on things thoe lol |
06-30-2012, 06:26 PM | #10 |
I have ran a 20t traxxas 550 can no prob on 8 nimh cells and a 12t 550 from traxxas no prob. I do run the slipper from Axial though, all stock drivetrain.
07-14-2012, 08:07 PM | #11 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
I have run the 20t wraith motor for about 2 months in my scx10, i stripped 3 spur gears, 2 idler gears, lots of stock driveshaft pins, and tore apart some integy steel driveshafts (demo'd them. hardcore). I run an duratrax Evader slipper and it holds up fine, i use the Axial slipper on my emaxx and it works great. The stock driveshafts aside from pins (make your own) handle a 20t no problem, the dingo kit has the HD lockers and HD bevel/pinion gears spo it held up just fine. The worst damage i did was tear open an old super-soft 2.2 badlands tire, now i have 3 hard ones and 1 super soft |
20T Wraith motor in a Honcho - Similar Threads | ||||
20t motor and 45t motor gearing question? | rcstrike | Newbie General | 1 | 11-16-2011 03:40 PM |
