02-27-2012, 03:31 PM | #1 |
Pebble Pounder Join Date: Oct 2011 Location: Wichita
| Links Length of Dingo
I was wondering if anyone knows what the length of the links are in the axial aluminum links kit. I bought the Dingo builders kit and was upgrading it to a 4 link. The Dingo builders kit comes with the lower aluminum but not the upper. Just the stupid plastic y link.
02-27-2012, 03:38 PM | #2 | |
Pebble Pounder Join Date: Dec 2005 Location: W. Richland
| Re: Links Length of Dingo Quote:
When doing a 4 link with the builders kit, I believe I used the plastic shorter links that came in the kit for the uppers. It changes the pinion angle, but works fine. You wont need to buy aluminum uppers. If you're not set on aluminum uppers and just want the 4 link or need something to hold you over until you can get the aluminum uppers, then you should still be able to do the 4 link. | |
02-27-2012, 03:57 PM | #3 |
Pebble Pounder Join Date: Sep 2009 Location: joppa,al
the top post need to be 80mm. either by using a 70mm + 10mm post or 60mm + 20mm post or so forth
Links Length of Dingo - Similar Threads | ||||
Length of the Links | jokerc72 | Axial Wraith | 0 | 07-08-2011 12:49 AM |
Length of links | 0lllllll0 | Axial SCX-10 | 21 | 02-14-2011 11:53 AM |
What length should my links be | bvitale | General Crawlers | 3 | 06-27-2007 10:16 AM |
length of links | kacz7895 | General Crawlers | 3 | 06-08-2007 05:45 AM |
Links- length and how many is necessary ?s | Tig | General Crawlers | 4 | 05-26-2007 12:15 PM |
