04-08-2012, 12:12 PM | #1 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| drive shaft mod.
yes i have searched, hard and long. i want to do the cheap drive shaft mod where you put epoxy and threaded bar inside the drive shaft. my question is what size bar do i use ? thanks in advance guys. |
04-08-2012, 01:30 PM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
| Re: drive shaft mod.
I'd imagine whatever is closest in size to the ID of the drive shaft. Sorry, I don't have one on hand to measure, although I'm sure it's probably been discussed somewhere on here.
04-08-2012, 01:51 PM | #3 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Use tubing, not a bar. Tubing is lighter and just take your driveshaft off and take it with you to a hardware store and see what fits.
05-01-2012, 08:48 PM | #4 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
I'm tryin to do the same thing with my truck!! I don't suggest home depot if ur goin for under 10 dollars like me. Maybe ace hardware??
05-01-2012, 09:32 PM | #5 |
Newbie Join Date: Mar 2012 Location: Canada
i just went to the bulk nail section and found ones that fit absolutly perfect, dab of sticky grease to keep em in, no problems even with a pro 4 3300
05-01-2012, 09:42 PM | #6 | |
My vendor status has been revoked Join Date: Feb 2012 Location: Oregon city
| Re: drive shaft mod. Quote:
ummm.. did you try looking at a single bolt or nail you could cut the head off of?.............. unless you live on easter island and metal doesnt exist causing a bolt to be over $10.. | |
05-01-2012, 10:20 PM | #7 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
Why do you need such a mod??? I've got 3+ year old STOCK driveshafts with zero failures......
05-01-2012, 10:55 PM | #8 | |
Pebble Pounder Join Date: Jan 2011 Location: Bramwell
shelf queens dont count. and if its three years old, doesnt mean its been drove everyday, and had the crap beat out of it. he is probably also talking about the new wb8 driveshafts which your 3 year old rig will not have on it. | |
05-01-2012, 11:04 PM | #9 |
| Re: drive shaft mod. Not a shelf-queen, boy. An old converted AX-10 with at least 1000 charges through it...........STFU.............. |
05-02-2012, 11:06 AM | #10 |
| Re: drive shaft mod. |
05-02-2012, 01:28 PM | #11 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
I used an old aluminum axial steering link from an AX10 kit. perfect fit. The link was scratched to heck to I put it in a drill with a piece of 400 grit sandpaper in hand and polished it smooth and it slid in the WB shaft like a hot knife through butter. Left the end with the inner threads facing out.. No I can install a screw and pull with pliers to remove the aluminum if I need to work on the shaft. |
05-02-2012, 03:32 PM | #12 |
Quarry Creeper Join Date: Jul 2009 Location: Buffalo area
I remember that thread. I think somebody even used a wooden dowel and epoxied it inside. Said it worked good, fit right, held up well, and was nice and light. Can get a 3-4 foot piece at any hardware store for 3 bucks too. |
05-02-2012, 03:46 PM | #13 | |
i've broke a number of stock shafts on just dirt messing around, you have to try harder not to break stock drive shafts than to break them. | |
05-02-2012, 03:59 PM | #14 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
The part you want starts at 5:13 |
05-02-2012, 04:33 PM | #15 |
Newbie Join Date: Apr 2012 Location: Australia
Hey lets see some pictures of these mods. With heavy beach use aint nothing last too long |
05-02-2012, 04:58 PM | #16 |
Newbie Join Date: Jun 2011 Location: Kent
thanx for the link
drive shaft mod. - Similar Threads | ||||
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
drive shaft ? | S ARR T 8 | Axial SCX-10 | 3 | 08-31-2010 10:03 AM |
***MIP C-Drive Drive shaft for the AX10...GIVEAWAY*** | Rockpiledriver | RCP Crawlers | 153 | 07-01-2008 11:18 AM |
Hummer prop shaft mod? | LAV25 | General Scale Talk | 3 | 05-12-2008 03:24 PM |
dRIVE SHAFT | Crazy Crawler | Newbie General | 5 | 10-12-2007 10:03 PM |
