05-08-2012, 06:09 AM | #1 |
Newbie Join Date: Apr 2012 Location: Swansea
| Help With scx10 motors please!
i have a scx10 been running an axial 20t motor for a while now but last night it burnt out so right after i switched to a axial 27t motor and different battery and within 20 minutes that motor burnt out too anyone know what can cause this? maybe my ESC is bad? i dont know
05-08-2012, 11:55 AM | #2 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| Re: Help With scx10 motors please!
Check that your bearings are free and nothing is binding. A also check your mesh. What gearing are you running? Im running 75/23 with Tamiya silver can. I never buy decent motors because i usually run in the filthiest water around. |
05-08-2012, 12:41 PM | #3 |
Pebble Pounder Join Date: Mar 2011 Location: St. Louis
What pinion and spur are you running? It sounds like your gearing is a little too high. I run new combinations for a few minutes then check for excessive heat. If it is too hot to comfortably touch for two seconds, gear down. I run a brushless with a heatsink, it is a whole lot less maintenance especially in a dirty dusty, wet enviroment.
05-08-2012, 04:46 PM | #4 |
i had the slipper clutch too tight thats why i was messing with these little bushes pushing them over and it would bind up and put to much load on the motors lol i have a 88/20, i run throught the nastiest water too im not nice to my crawler lol. i ran a 20 t motor for over an hour before never got hot but i messed with that slipper clutch and forgot to re adjust it. I bought a tekin 35t motor now and its good to go! thanks for replys
Help With scx10 motors please! - Similar Threads | ||||
Speed/Torque difference between Crawler motors/Normal motors? | dynamic_e | Electronics | 5 | 10-08-2010 10:26 AM |
