05-24-2012, 04:56 PM | #1 |
Rock Stacker Join Date: Feb 2011 Location: Sunshine Coast, Noosa
| Narrowing front Wraith Axle for front of scx10
Just wondering if it would be possible to shorten a wraith front axle to the same width of a scx10 rear axle. Then use the wraith axle up front in a scx10. Would it give a better turning circle? Also I think it would look more scale with a off center axle pumpkin up front. Looked at the XR10 steer mod with C hubs, knuckles and shortened cvd axles but the price for these parts seem to be double what standard alloy scx10 parts. So why not try something different. Thoughts? |
05-24-2012, 06:52 PM | #2 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
| Re: Narrowing front Wraith Axle for front of scx10
the housing wouldnt be an issue but the shafts would be that would be your weak point, the axles would have to be welded and heat treated or sleeved or something, i think its possible but iv never seen it done, if u do manage to pull it off to a tutorial so other people can fallow in your foot steps, like..... i dont know , me? lol
05-24-2012, 10:19 PM | #3 |
No worries mate. I was thinking of cutting the splined end off the housing. Cut housing shorter whats needed then cemi wield brass tube inside each axle housing so its sticking out enough to take the spline section for the c hubs. Ill be using Egressor non slop lockers and I was thinking of cutting the standard wraith universal shafts down and grinding a flat edge on the end to slip into the locker and tightened up. I think this would remain fairly strong. |
05-24-2012, 10:59 PM | #4 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
narrow the long side to match the short side then use 2 short axles. you may need wideners after but it would be the easiest way.
05-24-2012, 11:01 PM | #5 |
RCC Addict Join Date: Mar 2010 Location: Yelm
| Re: Narrowing front Wraith Axle for front of scx10 |
05-24-2012, 11:06 PM | #6 |
Thats right. keep the idea's coming.
05-24-2012, 11:22 PM | #7 |
05-25-2012, 12:06 AM | #8 | |
| Re: Narrowing front Wraith Axle for front of scx10 Quote:
05-25-2012, 12:16 AM | #9 | |
I dont see why cut down cvd shafts would be any weaker. Cheers Last edited by rusty577; 05-25-2012 at 12:44 AM. | |
05-25-2012, 12:17 AM | #10 |
05-25-2012, 12:43 AM | #11 |
02-02-2013, 12:55 PM | #12 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
Couldn't you buy 4 axle sets, take the short tube off of 2 of them then take the long tube off of the other 2 put the short tubes on the half axles with the short tubes attached to the pumpkin, and then put the scx10 internals into the short axles? just a though |
02-02-2013, 10:30 PM | #13 |
Scratch that. Just shorten the long half, put some brass tubing in for support and use the scx10 axle internals. Wouldn't that work?
Narrowing front Wraith Axle for front of scx10 - Similar Threads | ||||
front steering linkage behind front axle kit? | slip408 | Axial AX-10 Scorpion | 8 | 09-14-2008 01:16 AM |
