Thread: SCX10 Tranny Out put gear ratio????
Old 07-04-2012, 04:34 PM   #1
Default SCX10 Tranny Out put gear ratio????
Looking for the out put gear ratio for a stock tranny with a 20 tooth pinion. I put my Losi Comp Crawler tranny in it with a 20 tooth pinion on my 35 Turn Tekin on 3S lipo, lets just say it hauled some serious azz but the motor with up in smoke in about 2 minutes, I had now idea there was that much difference in the two gear ratios...
Needboost is offline   Reply With Quote
Old 07-04-2012, 07:36 PM   #2
Default Re: SCX10 Tranny Out put gear ratio????
the spur/pinion ratio you have is 4.35 to 1. To get that number divide 20 into 87. My guess is its the 3s and could also be your tire size, vehicle weight and/or your driving habits. My scx10 uses a 35t teken also with a 80 spur and 20 pinion which is 4:1 with a 2s and 1.9 flatirons, its almost 8 pounds and its plenty fast for me crawls great and has some pep when needed. If I where you I'd eather get a smaller pinion 16t-18t or drop to a 2s. Hope this helps.
thomanator is offline   Reply With Quote
Old 07-04-2012, 07:39 PM   #3
I answered your other question on the LCC forum. Since I also have an SCX10, I'll take a cut at answering this one also. The SCX10 trans ratio is 2.6 to 1. The ratio with the pinion will depend on what spur you are using. The equation is:
Spur/pinion X 2.6 = Ratio
Jerry
jgrim is offline   Reply With Quote
SCX10 Tranny Out put gear ratio???? - Similar Threads
Gear ratio of LCC tranny vs LNC tranny? shelljeep Team Losi Comp Crawler 10 02-07-2012 04:55 AM
Axial tranny gear ratio diggindeep Newbie General 4 10-29-2011 07:33 AM
Tranny gear ratio miller Team Losi Comp Crawler 3 09-11-2009 06:11 PM
rc10 tranny gear ratio CRAWLOVERYOU General Crawlers 3 10-21-2005 10:21 AM
emaxx tranny and pede tranny gear ratio questions CRAWLOVERYOU General Crawlers 3 12-28-2004 01:28 PM
