07-04-2012, 07:05 PM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: Canada
| battery placement
So my truck is a bit top heavy and i need to move the battery down and the electronics to the back i think. Anyone have some pictures of people doing this or any other creative way of having the electrics. I have an interior in my truck so i cant have the battery cross the frame or the body wont fit down over top of it. At the moment im limited to my stick pack as no more funds for toys for a while thanks Last edited by cguit; 07-04-2012 at 07:46 PM. |
07-04-2012, 08:56 PM | #2 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
| Re: battery placement
i run mine front to back on the rock sliders.
07-04-2012, 09:21 PM | #3 |
Quarry Creeper Join Date: Jan 2011 Location: Kingston NH
mine are 5500 saddle packs on the rock rails
07-04-2012, 09:57 PM | #4 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
I run my battery across the chassis rails where the electronics box generally goes. My receiver box has been moved to the back of the truck. Sent from my Transformer TF101 using Tapatalk 2 |
07-04-2012, 10:43 PM | #5 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
i run mine on top of the electronics box. i cut a groove into it and added a strap.
07-04-2012, 10:46 PM | #6 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
| Re: battery placement My first kit - Dingo Defender Hopefully my pics give you an idea of a nice free solution. |
07-05-2012, 12:46 AM | #7 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
I run mine on the rock rails as well, but need to come up with a different scenario for more weight forward. My Dingo still wants to roll over backwards on a steep incline even with weighted front wheels. |
07-05-2012, 01:44 AM | #8 |
Rock Crawler Join Date: Jun 2012 Location: Nevada Desert
Weight in the rear tires? Counter balance makes a ton of difference.
07-05-2012, 05:00 AM | #9 |
Quarry Creeper Join Date: Nov 2011 Location: In the woods
I run the rcp crawlers battery tray that lays across the frame. The esc is in an am machines mount and the rx box is on the battery tray. JEVNE*BATTERY/SEVRO*PLATE... |
07-05-2012, 04:53 PM | #10 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
here's how I have my electronics setup. battery isn't in the pic, but you can see the tray/strap for it up front. Top of battery is slightly lower than the shock mounting points. Battery is a 5000mAh hard-case Dynamite Speedpack LiPo. Rig is just over 8lbs |
07-05-2012, 06:22 PM | #11 |
Newbie Join Date: Oct 2005 Location: Millstadt
I've had the best results from my cut down stock battery mounts. Battery tray is even with the frame rails. Works better than a sideways battery across the frame, thats behind the front shock towers any day.
07-05-2012, 06:32 PM | #12 | |
| Re: battery placement Quote:
The Jevne battery tray looks like a plan as well other than the price. Maybe something like Bubba built. Lots of choices...just need to pick one and run with it. | |
07-05-2012, 09:43 PM | #13 |
FYI I built my own because I already had the RC4WD CMS bracket so I didn't need that part and well, it was free I think if you're running a CMS then the sideways mount is the way to go because there isn't even room for a forward battery (well not for me, I'm using a 5000mah hardcase lipo).
07-06-2012, 07:48 PM | #14 |
Well thanks for the suggestions, here goes attempt with the computer bay covers. |
07-06-2012, 08:03 PM | #15 |
Pebble Pounder Join Date: Feb 2011 Location: Knoxville
Here's mine, they are actually more forward than in this pic.(I had them mounted on the wrong sides in the pic) |
battery placement - Similar Threads | ||||
Battery placement ? | bluenosegoat | Venom Creeper | 5 | 02-21-2011 08:55 AM |
Battery Placement | will bell | Newbie General | 6 | 02-15-2010 11:41 PM |
battery placement | that4byguy | 1.9 Scale Rigs | 3 | 12-18-2009 09:14 PM |
battery placement | 209jeep | Newbie General | 5 | 02-02-2009 05:05 PM |
Battery Placement | twisted | Tamiya TLT Crawlers | 6 | 12-08-2006 10:20 PM |
