12-08-2012, 09:54 PM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: NorCal
| Quick ? On Robinson Racing Trans Gear's Install
Installing R.R. 1541 & 1542 idle gear and 1pc diff locker gear. Am I supposed to just use a standard set screw to attach the drive shafts to the 1542? The OEM gear has a hole all the way through each output shaft and the OEM set screw acts as a pin going all the way through. The new R.R gear has a flat side for a set screw (no hole for pin style screw)... ? Any other pertinent advise I should follow while Im in here? Thanks! |
12-08-2012, 10:16 PM | #2 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Quick ? On Robinson Racing Trans Gear's Install
Nope you use a short set screw. The output would be weakened if they would have pit hole through it.
12-08-2012, 10:19 PM | #3 |
You can use a set screw on each side. I think RR makes a Wraith output that has the holes. |
12-08-2012, 10:23 PM | #4 |
Right on guy's, that's what I assumed but I appreciate the quick confirmation |
12-09-2012, 08:13 AM | #5 |
Newbie Join Date: Sep 2011 Location: Youngstown
What size are the set screws that are needed? Just ordered those gears and mip driveshafts and would like to have the set/grub screws when i get them so i can get right back to using it
12-09-2012, 09:39 AM | #6 |
Quarry Creeper Join Date: Mar 2011 Location: Mn
They use m4 size screws. They should come with grub screws though.
12-09-2012, 10:10 AM | #7 |
I picked up a set of MIP's also, but I think Im just going to run the stock OEM shafts until they break before I install the MIP's...
12-09-2012, 10:43 AM | #8 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
I used an HPI 4 mm pin style...fit nicely Traxxas make one also. |
12-10-2012, 01:46 PM | #9 | |
| Re: Quick ? On Robinson Racing Trans Gear's Install Quote:
Great suggestion, I followed the advice. I ended up using 3mm X 5mm to reach the "flat" on the gear, and 3mm X 3mm on the other side (without "flat") along with blue threadlock | |
Quick ? On Robinson Racing Trans Gear's Install - Similar Threads | ||||
R2 trans vs robinson racing | 1kleanc | Axial SCX-10 | 3 | 11-21-2012 12:02 PM |
Robinson Racing Gears | CRAWLERJOE | Axial Wraith | 7 | 05-31-2012 05:33 PM |
Robinson Racing | TXJeeper1 | Chit Chat | 6 | 03-27-2012 10:10 PM |
