12-12-2012, 07:59 AM | #1 |
Rock Stacker Join Date: May 2011 Location: quebec city
| Scx10 with redline 10.5t
Someone have this setup in a scx10?? I would like to setup my scx in one tekin redline 10.5t, I ride one presently in tekin 35t hd 3s. do you think the 10.5t will have enough torque or it will run out?? THx for answer Thé esc was a mamba Max pro |
12-12-2012, 02:09 PM | #2 |
| Re: Scx10 with redline 10.5t
no one have it and can answer this?
12-12-2012, 11:44 PM | #3 |
Pebble Pounder Join Date: Aug 2007 Location: Switzerland
I don't have it in a SCX10 but have it in a Wraith. There it is a blast. Very fast and still crawls very well. The only limitation for the crawling ability is the limited drag brake I can use to prevent sudden stops when I release the trigger at high speed. The motor did not get hot even at slow crawling hill climbs. I'm using stock Wraith gears. What is the reason for you to put in that 10.5t? Speed with the ability to crawl? I would say you wouldn't be disappointed. How fast do you want it? My Wraith is crazy fast with that motor. Maybe a 13.5t would be the better choice. I think Harley have one in his SCX10 Jeep Rubicon. Maybe he can say more about it. |
12-13-2012, 05:55 AM | #4 |
my 35t hd motor was dead and i a have a big deal on a tekin 10.5T redline brand new from my friends for a big 20$ lol so i have a mamba max pro here on my tablet :P its very cheap deal for replace the BEEP 35t hd |
12-13-2012, 08:58 AM | #5 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
You should get it just to have it even if you don't use it all the time. Never know when you need speed for bashing on a trail |
12-13-2012, 12:40 PM | #6 |
Rock Stacker Join Date: Mar 2011 Location: powhatan
sounds great go for it. |
12-13-2012, 01:29 PM | #7 |
thx for answer but with 14/87 gearing or i put a pinion with 13 or 12T
12-13-2012, 01:33 PM | #8 |
Kinda close but here is a 13.5 Redline with Mamba Max Pro. 21/87 gearing. It crawls great and has pep too. I wish I could get a 22 or 23 pinion on but I would have to trim the motor plate. Two videos show the differences. I figure the 10.5 with the pinion gears you are referring too will get you close in the gearing department. And for $20, I would get that motor. Szczerba's IFS SCX Build .. |
12-13-2012, 02:21 PM | #9 |
so i try it and i see if this motor was overkil or not in the scx 10 |
Scx10 with redline 10.5t - Similar Threads | ||||
Redline Bandit | BJoe | Non Crawler RC's | 8 | 01-08-2009 11:30 PM |
