01-02-2013, 11:05 AM | #1 |
Newbie Join Date: Jan 2013 Location: Boston
| SCX10 Dingo bullet proof transmission
This is the first project to upgrade my SCX10 dingo - I'm going to build a bullet proof transmission. These are parts I just ordered last night: 1. Hot Racing Aluminum Transmission Casing Upgrade for AX10 SCX10 Crawler Rock 2. Robinson Racing Axial Scorpion Crawler Outdrive Diff Lock Gear Ax10 RRP1542 3. Robinson Racing Hard Steel Idler Gear AX10 4. Robinson Racing Slipper Unit 88T Steel Spur Gear AX10 5. WRAITH & AX-10 BEEFY TOP SHAFT 6. L3 AXIAL SCX10 DUAL MOTOR MOUNT I will submit more photos as soon as everything coming. Last edited by errorbug; 01-02-2013 at 12:07 PM. |
01-02-2013, 12:40 PM | #2 |
| Re: SCX10 Dingo bullet proof transmission
These are additional parts to upgrade drive shafts. I don't know if they are necessary for my new tranny. I heard about the new SCX10 shaft yoke is not working with Robinson outdrive gear very well (always loose connection). MIP Spline Set Center CVD Kit (SCX10) MIP10145 Traxxas Screw Pins 4x13mm w/Threadlock Last edited by errorbug; 01-02-2013 at 12:43 PM. |
01-02-2013, 01:52 PM | #3 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
Why go with two motors? Why not just one good quality one and volt up?
01-02-2013, 03:39 PM | #4 | |
| Re: SCX10 Dingo bullet proof transmission Quote:
This is my current motor setup: TRAXXAS STAMPEDE VELINEON 3500 BRUSHLESS MOTOR & VXL 3S ESC SPEED CONTROL 3350X My future plan is two brushed motors if the current setup is not powerful enough for my dingo snow plow. Last edited by errorbug; 01-02-2013 at 03:43 PM. | |
01-08-2013, 06:29 PM | #5 |
This is the finished bullet proof tranny. I'm just amazed how tight everything fitting together even they come from different vendors. |
01-08-2013, 08:54 PM | #6 |
Quarry Creeper Join Date: May 2012 Location: Houston
Very Nice, who makes that tranny mount?
01-08-2013, 09:12 PM | #7 | |
Pebble Pounder Join Date: Aug 2012 Location: Finland
01-09-2013, 02:47 PM | #8 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
I took my RRP gear to work and had a guy in the machine shop drill holes in the flats on the gear for the screw pins to go thru, that way I didn't have to use set screws to hold the drive shafts on.
01-09-2013, 03:13 PM | #9 |
Grub screws will stay tight on the robinson gear if you loctite them in. Nice trans, if the single brushless doesn't have enough oomph then 2 brushed won't be much better. I'd go with a single large brushless and be done with it. |
01-09-2013, 04:50 PM | #10 | |
One more thing about L3 mount plate, you may get hard time to fit the big brushless motor to the low position. For dual mounting plate, you can choose to mount big motor in the high position. Last edited by errorbug; 01-09-2013 at 05:46 PM. | |
01-09-2013, 04:58 PM | #11 |
| Re: SCX10 Dingo bullet proof transmission |
07-25-2013, 08:17 PM | #12 |
Newbie Join Date: Jul 2013 Location: Westchester
I want replacements for the stock gears, plastic teeth have stripped does anybody have the aluminum or metal gears that fit in place without changing the housing?
SCX10 Dingo bullet proof transmission - Similar Threads | ||||
Bullet Proof Build | powerhound | Axial XR10 | 13 | 04-22-2012 01:21 PM |
