01-22-2013, 09:33 PM | #1 |
I joined the Band! Join Date: Aug 2009 Location: Maryville, Tn
| Dingo 4 link ?
The stock plastic links that came extra in the kit are too long. Anyone know what length the top ones need to be on the rear. Better yet anyone have some?
01-23-2013, 12:08 AM | #2 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
| Re: Dingo 4 link ?
i run Traxxas Revo TRA 5318 pushrods for my links , front, rear lowers and rear uppers . works great and cheap |
01-23-2013, 12:25 AM | #3 |
I can't use the same links as the bottom they are two long unless u can adjust them with the thread ends
01-23-2013, 12:32 AM | #4 |
Best I can figure I need some links eye to eye about 80-81 mm. Any ideas who makes em on the cheap. About 10 mm shorter than the lowers......
01-23-2013, 06:17 AM | #5 |
| Re: Dingo 4 link ?
are you using the 4 link on the rear ? if so the links are the same length. here is my rebuild thread New to me Dingo |
01-23-2013, 12:14 PM | #6 |
Pebble Pounder Join Date: Jan 2012 Location: McPherson
| Re: Dingo 4 link ?
You can always build you own links. There is a lot of info on how to do that in the how to section.
01-23-2013, 08:11 PM | #7 |
Pebble Pounder Join Date: Dec 2011 Location: Wherever you are not
| Re: Dingo 4 link ? I found the same problem with my Dingo when trying to 4link with the extra links supplied in the kit. I came up with ~ 4.25" eye to eye (sorry I'm sticking to standard units for now). I went to the hardware store and picked up some 3/16 x .049 aluminum tube, $2.50. Cut it to 3 3/8" tap it and the extra eye links for a 4-40 install a set screw and assemble. Hope this helps |
01-23-2013, 08:29 PM | #8 |
| Re: Dingo 4 link ? |
01-23-2013, 08:42 PM | #9 |
Pebble Pounder Join Date: Nov 2009 Location: Waterford , PA.
| Re: Dingo 4 link ?
Here are the link measurements from Axials website. I use rear lower links on top in the rear for a better pinion angle. http://docs.axialracing.com/instruct...cx10-links.pdf |
01-23-2013, 10:12 PM | #10 | |
Dingo 4 link ? - Similar Threads | ||||
4 link in dingo | sandrocks | Axial SCX-10 | 16 | 01-10-2013 03:40 AM |
Dingo Link Lengths | grizzlypaugh | Axial SCX-10 | 14 | 07-06-2012 06:38 PM |
Upgrading a Dingo to 4 link suspension | kitsched | Axial SCX-10 | 15 | 03-27-2012 01:50 AM |
SCX10 Dingo 4-link | Coops | Axial SCX-10 | 7 | 05-05-2011 09:29 PM |
dingo 4-link | jon1197 | Axial SCX-10 | 2 | 03-03-2011 10:48 AM |
