Thread: SCX10 F150 Supercab guys!
Old 03-20-2013, 03:38 PM   #1
Default SCX10 F150 Supercab guys!
What are you running for driveshafts? My rough measurements are 6" rear shaft and 5.5" front. Not sure if even the Mip Axial female with the Summit male side is long enough?
Hyde is offline   Reply With Quote
Old 03-20-2013, 04:45 PM   #2
Default Re: SCX10 F150 Supercab guys!
I am running wraith mip shafts with both the long outputs at the rear. I am also running a vp dig for 2wd/4wd ability, this increases the length of your transmission making you need shorter driveshafts. If you do not want to run a dig use a wraith transmission as it will give the same effect.
If you would like pics there are some in my build thread.
ax-10 crazy is offline   Reply With Quote
Old 03-20-2013, 10:48 PM   #3
Thanks for the suggestions, ill check out your thread when I'm back to the computer. What do you mean by long outputs? And anyone else?
Old 03-21-2013, 10:40 AM   #4
Summit male side
What is that?
Standard SCX10 outputs are 5mm.
Last night installed 104-150mm RC4WD punisher shafts. They are just a few mm longer than stock WB8 shafts.
nersik is offline   Reply With Quote
Old 03-21-2013, 10:46 AM   #5
Originally Posted by nersik View Post
What is that?
MIP Spline CVD™ Bone, Traxxas Summit (1) #9169
Will fit in place of the MIP Axial male splines, dont know what overall length comes out the be though
Old 03-22-2013, 03:53 PM   #6
Can anyone give me the assembled measurement of the MIP Axial female splines with the Summit or Maxx male splines?
Old 03-22-2013, 05:52 PM   #7
Hang on.
BAWLER CRAWLER is offline   Reply With Quote
Old 03-22-2013, 05:59 PM   #8
Old 03-23-2013, 12:09 AM   #9
Thank you! It that the summit male or maxx male?
Old 03-23-2013, 07:21 PM   #10
Summit
Old 03-24-2013, 10:56 AM   #11
Perfect thanks a ton!
Old 03-24-2013, 07:52 PM   #12
Thanks, I needed that pic too! Ive been having a problem finding ones that'd fit my length.
Originally Posted by BAWLER CRAWLER View Post
badBKO is offline   Reply With Quote
Old 03-25-2013, 08:37 AM   #13
You're welcome, it took some searching but I figured I I'm gonna go through the trouble of extending the shaft it's just gonna be one time. I ran the stock scx mip in the front til I switched to trex60 axle and added another 1/4" of wheelbase up front for better approach, I had to lengthen that one myself.
SCX10 F150 Supercab guys! - Similar Threads
Project "Big Blue" 1979 F150 Supercab ax-10 crazy Axial SCX-10 74 04-04-2015 08:09 PM
1979 F150 supercab build 80%finished(lots of pics) BAWLER CRAWLER Axial SCX-10 28 06-13-2012 09:47 PM
