03-20-2013, 03:38 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: CDA
| SCX10 F150 Supercab guys!
What are you running for driveshafts? My rough measurements are 6" rear shaft and 5.5" front. Not sure if even the Mip Axial female with the Summit male side is long enough?
03-20-2013, 04:45 PM | #2 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| Re: SCX10 F150 Supercab guys!
I am running wraith mip shafts with both the long outputs at the rear. I am also running a vp dig for 2wd/4wd ability, this increases the length of your transmission making you need shorter driveshafts. If you do not want to run a dig use a wraith transmission as it will give the same effect. If you would like pics there are some in my build thread. |
03-20-2013, 10:48 PM | #3 |
Thanks for the suggestions, ill check out your thread when I'm back to the computer. What do you mean by long outputs? And anyone else?
03-21-2013, 10:40 AM | #4 | |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
| Re: SCX10 F150 Supercab guys! Quote:
Standard SCX10 outputs are 5mm. Last night installed 104-150mm RC4WD punisher shafts. They are just a few mm longer than stock WB8 shafts. | |
03-21-2013, 10:46 AM | #5 |
| Re: SCX10 F150 Supercab guys! MIP Spline CVD™ Bone, Traxxas Summit (1) #9169 Will fit in place of the MIP Axial male splines, dont know what overall length comes out the be though |
03-22-2013, 03:53 PM | #6 |
Can anyone give me the assembled measurement of the MIP Axial female splines with the Summit or Maxx male splines?
03-22-2013, 05:52 PM | #7 |
Pebble Pounder Join Date: Feb 2011 Location: Knoxville
Hang on.
03-22-2013, 05:59 PM | #8 |
03-23-2013, 12:09 AM | #9 |
Thank you! It that the summit male or maxx male?
03-23-2013, 07:21 PM | #10 |
03-24-2013, 10:56 AM | #11 |
Perfect thanks a ton!
03-24-2013, 07:52 PM | #12 |
Rock Crawler Join Date: May 2007 Location: floriduh
| Re: SCX10 F150 Supercab guys! |
03-25-2013, 08:37 AM | #13 |
You're welcome, it took some searching but I figured I I'm gonna go through the trouble of extending the shaft it's just gonna be one time. I ran the stock scx mip in the front til I switched to trex60 axle and added another 1/4" of wheelbase up front for better approach, I had to lengthen that one myself. |
SCX10 F150 Supercab guys! - Similar Threads | ||||
Project "Big Blue" 1979 F150 Supercab | ax-10 crazy | Axial SCX-10 | 74 | 04-04-2015 08:09 PM |
1979 F150 supercab build 80%finished(lots of pics) | BAWLER CRAWLER | Axial SCX-10 | 28 | 06-13-2012 09:47 PM |
