02-14-2013, 10:06 AM | #1 |
Newbie Join Date: Jan 2013 Location: canada
| Will this solve 8 degree Vanquish knuckle wheel clearance
I am installing some upgrades to the Honcho. Links,servo,axles,wheels.tires,etc and vanquish stage one kit. The stage one kit with the 8 degree knuckles may cause a tire clearance problem. I bought an extender kit but would rather not use it. So I am going to try reversing the wheels. They are RC4wd 1.9 beadlock steel wheels. I thought I would put the outside of the wheel with the shallow dish on the inside which would place the wheel further from the knuckle and give me more room between the tire and the links. As you have guessed I am new to this so if you see problems please tell me. I will post result, good or bad. Moe |
02-26-2013, 07:33 PM | #2 |
Quarry Creeper Join Date: Sep 2012 Location: Orange County, CA
| Re: Will this solve 8 degree Vanquish knuckle wheel clearance
Hey Moe, I'm in the midst of the same problem.....I have a Honcho did the Axial Links, RC4WD DC 1.9 beadlocks, Pitbull tires and the Stage 1 kit from Vanquish. Bottom line, I need 12mm hex extenders and a lengthened steering linkage to make the Vanquish kit work. I got a hold of some TLR 22sct hexes in the +1.5mm size and they work. Just waiting on Amain to deliver the Vanquish Steering linkage (For currie Axles) although I have confirmed that it is the right length. Fingers crossed! |
02-26-2013, 07:36 PM | #3 |
RCC Addict Join Date: May 2011 Location: Utah County
I would try wider hexes before reversing the dish on your wheels. But yes. That should work. You might be new but you've obviously done great research and are doing things right so good job Sent from my SCH-I535 using Tapatalk 2 |
02-26-2013, 08:59 PM | #4 |
Newbie Join Date: Mar 2008 Location: Puyallup
They also sell different hubs you can use to push you wheel out further to get the clearance you need.
03-03-2013, 04:21 PM | #5 |
All worked out! The Ti currie steering links worked perfect! Sent from my iPhone 5 using Tapatalk |
03-03-2013, 06:50 PM | #6 |
Finished installing the upgrades but ran into a problem with the tie rod link being to short by about 12mm. It was for the stock axles housings and Vanquish are about 12mm wider. I was happy with the shape of the link so wanted to extend it. Searched the net for longer ball links but could find nothing, then I discovered a set of turnbuckle links with longer ball links from Traxxas and I put these ball links on my tie rod and it worked perfect. I am now trying to learn how to paint using an air brush. I find the biggest challenge will be mixing paint to the right consistency so it doesn't sag etc. Nothing but fun,fun,fun. Oh yea I forgot to mention that reversing my RC4wd bead lock wheels did not work. I have ordered a set of 9mm off set hex adapters by RC4wd that should work fine and not be as wide as the 13mm ones I have now. Moe |
Will this solve 8 degree Vanquish knuckle wheel clearance - Similar Threads | ||||
8 degree knuckle weights | bigron | Axles, Trannys, T-case | 20 | 09-06-2011 10:02 PM |
30 degree angle high clearance links for the front | TACORICAN | Axial AX-10 Scorpion | 4 | 10-30-2010 11:24 AM |
30 Degree link clearance? | Deezul | Axial AX-10 Scorpion | 4 | 05-05-2008 01:51 PM |
