Thread: New Honcho owner - hopefully some easy questions
Old 02-06-2013, 07:08 AM   #1
Default New Honcho owner - hopefully some easy questions
Hey guys... My honcho will be at my doorstep waiting for me when I get home from work. I just got the RTR version to get used to the whole crawler/scaler thing.... I'm used to 1/8 buggies. I plan this summer to tackle a Tundra truggy build when I get a little better with figuring out what works and what doesn't.
Here is my questions though.... What would be some good initial upgrades to make to the truck? I was planning on tires and beadlocks, the metal links, and possibly a motor down the road sometime (holmes probably) but dont know what turn motor would be good. I plan on just doing some crawling around here and there.... no comps or anything serious like that. What am I missing, or is that a solid start??
Also..... any cheap/free mods that can be done to improve anything?
crfnick56 is offline   Reply With Quote
Old 02-06-2013, 07:55 AM   #2
Default Re: New Honcho owner - hopefully some easy questions
If you check out the stickies at the top of the scx10 section, there is a thread 5+ pages long on both of those questions.
I have read through them and there is a whole bunch of usefully info in there.
Benjamin is offline   Reply With Quote
Old 02-06-2013, 07:59 AM   #3
Yea, I read through all those too but my real question was more like what else besides what I mentioned would be a good start?
Old 02-06-2013, 08:26 AM   #4
You can always remove the factory bump stops on the shocks for some more flex, and then from there just replace stuff as it breaks or no longer performs the way you want.
Old 02-06-2013, 01:52 PM   #5
if you already read the tips and tricks, then you know what some think is essential -- i'd just run it a lot and figure out what your needs are as you go. IMO most important thing in the beginning would be to have a backup battery so you can keep going!
Perkolator is offline   Reply With Quote
Old 02-26-2013, 10:26 PM   #6
Hey, as a new honcho owner myself......here's what I upgraded first:
Axial links/steering links
steering servo to savor 1283sg
Wheels to rc4wd deadlocks
firestorm pit bull rock beasts
I did a bunch more, but those are the mists
Check out my videos on YouTube at "The RCNetwork" probably about 20+ so far on hoNcho
RichMTB01 is offline   Reply With Quote
Old 02-26-2013, 10:29 PM   #7
God, my spell. Check jacked that post up!
Savox
Beadlocks
Tires to Pit bull.....
Old 02-26-2013, 11:12 PM   #8
Also only had my honcho for a few months and I built mine basically in that order but first I got 1.9 swampers and cut the foams
Dr.Newb is offline   Reply With Quote
Old 02-27-2013, 12:46 AM   #9
Really only two things come to mind, the biggest thing to upgrade is to aluminum links and RRP aluminum output transmission gear as soon as possible, everything else is on a "breaking" basis at that point, really not that much even breaks at all if anything some plastic stuff warps, it really depends on how you drive and what you drive through.
Usually with me once I bullet proff the transmission line the next set of stuff to go out has usually been the electronics at a farther point then small stuff like the plastic turning knuckles although it took a 1,200 horse to break my plastic turning knuckles (long story short I drove my scx10 in a pasture and a horse stepped on it) the new stock electronics on the RTR is actually top of the line for an RTR, 2.4ghz radio, castle made esc, exc. so your pretty much set just with electronics and for what everyone is suggesting.
arctichorse is offline   Reply With Quote
New Honcho owner - hopefully some easy questions - Similar Threads
New owner, couple of questions concretejungle Axial XR10 10 12-02-2011 11:04 AM
New LCC owner, some questions dont slow down Team Losi Comp Crawler 23 09-21-2010 02:52 PM
help new honcho owner! cool94beans Newbie General 20 07-30-2010 12:18 AM
New AX-10 owner questions Trimmy Newbie General 4 12-28-2007 06:33 PM
New WK owner with questions RC_Feen HPI Wheely King 5 04-21-2007 09:11 PM
