Thread: Vanquish Currie Axles and SLW hub question
Old 03-11-2013, 03:18 AM   #1
Default Vanquish Currie Axles and SLW hub question
Hi guys,
i ve been reading this forum fanatically and I ve been infected with the scaler virus for the last 2 months now. Unfortunately most nice parts I need to order from the US and shipping and import taxes are quiete expensive. So I thought I d ask you guys first before placing an order, since I need to wait another week and pay shipping again in case I ordered the wrong parts or forgot to order something.
I have the SCX10 Jeep Rubicon and I want to add the Vanquish Currie Axles and OMF beadlock wheels.
From what I understand I need to order the 8° chubs and knuckles with it to fit, right or are they optional? But I want to order them anyways for my setup. Are there any problems to make it fit with the wheels? Any other hardware needed? Next I will add the 10pcs Vanquish titanium link set also.
Next question would be: which SLW hubs do I need to order to clear the steering setup?do the hubs give the car a wider stance also?
buddamonk is offline   Reply With Quote
Old 03-11-2013, 05:16 AM   #2
Default Re: Vanquish Currie Axles and SLW hub question
I have used .600 hubs with my curries and omfs, and yes the links will keep the wheel base the same.
blumaro is offline   Reply With Quote
Old 03-11-2013, 05:26 AM   #3
You will need the 600 hub to clear the steering.You will not need anything elso.But rember you will need 3sets of screws for the rims if you order 5 rims
1beatjeep is offline   Reply With Quote
Old 03-11-2013, 07:27 AM   #4
Yeah, put that on my list already the 3x Screw set. :-)
Old 03-11-2013, 08:49 AM   #5
If you need any other info just ask.
Old 03-11-2013, 09:31 AM   #6
Yep I have the 600's as well, but I would recommend a 225 for the spare tire holder. I messed up and ordered a 600 for the spare as well, and had to modify the tire carrier to make it work.
MTRC is offline   Reply With Quote
Old 03-11-2013, 09:35 AM   #7
If I remember correctly, harley & a couple other guys are running the 350-475 hubs, the 600's will widen ur stance a little so if u want to tuck them in more go with the 475's
Dtempleton is offline   Reply With Quote
Tags
beadlock wheels, currie axles, omf, vanquish
Vanquish Currie Axles and SLW hub question - Similar Threads
Vanquish SCX10 Currie Axles IN Stock RPP Hobby RPP Hobby 2 03-26-2015 07:54 PM
FOFF Whiplash on Vanquish Currie axles 1tonscout Formula Offroad 34 07-18-2013 06:44 PM
Vanquish slw hub size XJkid93 Tires and Wheels 5 06-24-2012 05:02 PM
Vanquish SLW V3 on Bully Axles which hex hub size???? vodka child RC4WD Bully 17 07-16-2010 10:43 AM
