04-06-2013, 07:12 PM | #1 |
Rock Crawler Join Date: May 2012 Location: Columbus
| First BUILD
well im trying ill take opinions but this is it so far added lights and grill plus whatever the other black covers are called added overhead lights no bulbs yet added a lil extra to the arm and had to put spacers between the servo plate and axle but i feel like the servo isn't doing its best any suggestions moved the esc to back and put the on/off switch to a easy access spot flipped trany and put in a 62 tooth spur plus spacers between the motor and skid plate in upcoming buys im getting aluminum steering link atleast 102mm shocks and vq steering knuckles also some bead-locks too. |
04-06-2013, 07:16 PM | #2 |
RCC Addict Join Date: May 2011 Location: Utah County
Lookin good. Clean work. Aluminum links/steering will be a good upgrade for ya. Keep it up! Sent from my SCH-I535 using Tapatalk 2 |
04-06-2013, 10:18 PM | #3 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
| Re: First BUILD
You should consider removing that tamiya plug all together and soldering the plug straight. or clip just the tamiya plugs out, strip the wires and solder them together (and a little shrink wrap!) Love the accessories up top. Good looking build! |
04-06-2013, 10:50 PM | #4 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: First BUILD
Did you raise the servo, then cut a horn and screw it on as an extension? Were you not able to get a full steering throw? I was able to get full steering throw with the blue hitec arm and that same servo, and my endpoints were still under 100% on my radio. The Tamiya plug will be fine on a crawler, but you have the male end of the Deans right there, so if you have access to a soldering iron you may as well put it directly on the ESC. I think it's time to get it a little dirty and scratched up. |
04-07-2013, 09:31 AM | #5 | |
| Re: First BUILD Quote:
04-07-2013, 11:09 AM | #6 |
Quarry Creeper Join Date: Jul 2010 Location: Canada
| Re: First BUILD
the longer the arm the less torque the servo can deliver. If the servo is sucking wind you could add a bec or take off the extension.
04-07-2013, 03:13 PM | #7 |
| Re: First BUILD |
04-07-2013, 08:59 PM | #8 |
More travel. Yes. But less torque is correct. If a servo delivers 300oz/in that's with a 1in servo horn. 300 ounce over 1 inch If you use a 2"servo horn you'll only feel 150oz of torque out of it because you doubled the denominator without changing the numerator. The maths sucks Sent from my SCH-I535 using Tapatalk 2 |
04-09-2013, 05:49 AM | #9 |
| Re: First BUILD
so i picked up theses from RC4WD and cant wait to get them (Gmade ZERO Shock Black 104mm)Gmade ZERO Shock Black 104mm (4) i seen some good reviews on them |
04-09-2013, 06:15 AM | #10 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: First BUILD
Front end looks great. Very Defender like. The rear needs scaling up though. Nice rig...
04-09-2013, 11:24 AM | #11 |
Newbie Join Date: Feb 2013 Location: San Jose
| Re: First BUILD
Nice start! The dingo was my first scaler build and havent stopped adding to my fleet since. +1 for the bec comment and the links. They make a huge difference. One will provide the needed voltage to power the servo, and the links will help with clearance, steering, and adds rigidity overall. Was that an RTR honcho with a dingo body? I swear the dingo kit came with aluminum links. Great start either way. Theres tons of tips and tricks here with no lack of friendly people to help. |
04-09-2013, 12:18 PM | #12 | |
honcho just changed the links but gonna change them soon to somthing then plastic but did pick up mip's and knuckles+steering link but 1 question with the bec what one do I get ive seen a few different ones running stock esc and 6200 2s lipo | |
04-09-2013, 04:45 PM | #13 |
| Re: First BUILD
there ya go WIZ that better.. |
First BUILD - Similar Threads | ||||
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
need some help with a build idea.. want to build a military trucks | m1009cucv | Axial SCX-10 | 4 | 05-03-2011 02:28 PM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
