Thread: Hub size?
Old 04-10-2013, 01:37 AM   #1
Default Hub size?
Hello Folks.
I'm after some Mayhem Engineering Slamerz for Rubi. The hub sizes I'm looking at are the 0.650 and 0.750 but I can't decide which. I take it these are 0.650 centimetres?
I want the stance to be a little wider but not look ridiculous. Any advice and examples of what you are using?
o0wiz0o is offline   Reply With Quote
Old 04-10-2013, 05:06 PM   #2
Default Re: Hub size?
Don't go crazy with wide hubs. Axle shaft thread is not unlimited. You will not be able to secure wheels with nuts. Unless you go with bolt nuts.
I used traxxas 5mm hubs and there is no space for hub nut covers.
my thread
nersik is offline   Reply With Quote
Old 04-11-2013, 12:47 AM   #3
I went for the 0.650's. I like the look of Benders JK and I know he used 725 VP hubs. I didn't want wider than his so that seems the sweet spot. I'll post some pics when they arrive in 1-2 weeks.
Hub size? - Similar Threads
VP hub screw size? Boomstk74 Tires and Wheels 3 01-02-2013 07:25 AM
Hub size? Constant Threat EnRoute Berg 5 12-06-2012 08:26 AM
hub size? dynamaxxed Axial XR10 5 12-16-2010 06:39 PM
hub size lizard017 Newbie General 5 12-06-2008 03:25 PM
what size mm is the nylint hub 12flex General Crawlers 8 05-18-2006 10:28 AM
