04-14-2013, 02:43 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: UK
| Rotating the drives shafts to protect the splines?
My drive shafts are as pictured below and I assume this is how they all are stock? The lower parts that slides in to the shaft is getting roughed up as it hits rocks damaging the splines. Can I not (Am going to try) install the drive shaft the other way round? It will then protect the splines and also cause less hooking up on debris as the outer is smoother... |
04-14-2013, 03:25 AM | #2 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: Rotating the drives shafts to protect the splines?
I always install my shafts the other way around, I haven't used the wb8 shafts but can't see a problem.
04-14-2013, 06:18 AM | #3 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Make some rear upper links that approximately 6 mm longer than stock. Sent from my Desire HD using Tapatalk 2 |
04-14-2013, 06:22 AM | #4 |
Rock Crawler Join Date: Oct 2011 Location: Canada
Yeah, first turn them the other way, but more importantly, adjust your driveline angle by adding spacers, or making new rods as mentioned above. it will tuck the whole shaft up under the links.
04-14-2013, 06:44 AM | #5 |
Thanks folks. On the stock plastic rods at the moment so will look at replacing those soon.
04-14-2013, 10:56 AM | #6 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
i use rc4wd shock boots on my scale punisher shafts
04-14-2013, 05:27 PM | #7 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
You can also do the 3mm link mod to the drive shafts and it makes them pretty bomb proof.
04-14-2013, 05:49 PM | #8 |
Newbie Join Date: Feb 2013 Location: Las Vegas
its possible. I did it on mine and works fine
04-14-2013, 05:55 PM | #9 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
on the rear axle i use upper links that are the same length as the lowers. it clocks the axle up and keeps it from hitting on everything.
04-14-2013, 06:31 PM | #10 |
Rock Crawler Join Date: Oct 2012 Location: Casper
You can gain a small amount just by putting the lower link on the outside and the shock on the inside of the axle mounts. You may have to use a spacer at the top mount of the shock to keep it from hitting the frame, though.
04-15-2013, 01:38 AM | #11 | |
| Re: Rotating the drives shafts to protect the splines? Quote:
I also tried this but did get shock rub. I think I need to make/buy some links to resolve the chatter. The splines are now protected though. | |
04-15-2013, 01:43 AM | #12 |
RCC Addict Join Date: May 2011 Location: Utah County
3mm link mod? Sent from my SCH-I535 using Tapatalk 2 |
04-15-2013, 01:46 AM | #13 |
Where you put metal rod in the drive shafts to toughen them up. I shouldn't need this running stock. The Wraith never twisted them so am sure the SCX10 in stock for will not.
04-15-2013, 07:50 AM | #14 |
Pebble Pounder Join Date: Nov 2011 Location: Muskoka, Ontario
If your running in water/mud, debris gets into the shaft and jams them up when flipped.
04-15-2013, 07:54 AM | #15 |
Good point. But cleaning them from time to time is less costly than them being road-rashed to death! Haha
04-15-2013, 10:30 AM | #16 |
Rotating the drives shafts to protect the splines? - Similar Threads | ||||
making solid drives shafts | redsawacs | Axial SCX-10 | 3 | 04-13-2013 03:49 PM |
Do Junfac Shafts and MIP C Splines have Different Lengths for Front and Rear?? | alexchen86 | Newbie General | 0 | 07-22-2010 02:08 AM |
protect | clod saleen | Tamiya Clod Buster | 3 | 12-25-2006 03:34 PM |
