04-18-2013, 08:20 AM | #1 |
Newbie Join Date: Apr 2013 Location: Grand Rapids
| Dingo to Honcho Conversion
Does anyone know the part numbers of the parts required to convert my Dingo into a Honcho? I have spent some time looking through the manuals online to compart parts and part numbers but am still not sure I got the correct ones. Thanks in advance for the help. |
04-18-2013, 09:50 AM | #2 |
Rock Crawler Join Date: May 2012 Location: Columbus
| Re: Dingo to Honcho Conversion
all there is, is wheel base which if u go to axial site and click on honcho then instructions and go through them it will show u the part tree numbers AX80043 AX80054 usually the longer ones are on top and shorter are on bottom that way you can clock your axles |
04-18-2013, 12:05 PM | #3 |
Newbie Join Date: Apr 2013 Location: Moscow, Russia
With what drafts you want to make? I did with aluminum drafts. For 4-links it is necessary forward top drafts AXA1429 - 2 AXA1422 - 2 forward bottom drafts AX30518 - 2 back top drafts AXA1429 - 2 AXA1424 - 2 back bottom drafts AX30516 - 2 |
04-18-2013, 12:32 PM | #4 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
As Ohioskills said all you need is links. Refer to my post for links length and some clocking theory. Longer ones are are on bottom and shorter on top. If you switch them you will get insane axle clocking and shorter wheel base. |
04-18-2013, 12:46 PM | #5 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: Dingo to Honcho Conversion |
Dingo to Honcho Conversion - Similar Threads | ||||
Another Honcho or Dingo | xCoolHandLukex | Axial SCX-10 | 5 | 09-17-2012 06:02 PM |
Honcho or Dingo?? | geekfreek95 | Axial SCX-10 | 11 | 02-23-2011 10:07 PM |
**SW33TS Dingo conversion to MONSTER ZOOKS FJ40 with 110mm lift kit and 2.2** | gymjunkie23 | Axial SCX-10 | 7 | 08-29-2010 06:25 AM |
SCX-10 CF100 to honcho conversion | norbyx | Axial SCX-10 | 3 | 08-26-2010 09:24 AM |
Honcho leaf spring conversion | crawlerax | General Scale Talk | 1 | 08-20-2010 01:38 PM |
