07-04-2013, 10:11 AM | #1 |
| Chub Screw's backing out
OK... not the only issue... as the "C" knuckle screws (kingpins) also seem to loosen/back out over time used. Then combined... they create wheel/tire hub slop. I realize vanquish and others sell alloy parts to replace/improve... But even with those... the screws would still screw into the plastic axle housing. * No they're not stripped ! I was told by another that some blue locktite would help keep those seated. But was worried if those could booger up the insert threads ? Anyone else have this issue ? Locktite the temp fix ? Any issues removing the screw(s) down the road ? Any other advise regarding ? |
07-04-2013, 10:15 AM | #2 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| Re: Chub Screw's backing out
no my knuckles have an issue with it but my chubs to housing i had no issues after putting blue locktite on my knuckles i need to get some integy kingpins since they seem to be the only one who makes them
07-04-2013, 10:16 AM | #3 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
Yeah blue loctite will work well. I've used it in plastic a lot
07-04-2013, 10:24 AM | #4 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Get rid of those woodscrew style screws going into the plastic and pick up the same size in a machined thread. Then, use either blue Locktite or CA Glue to help hold it in the plastic. The little plastic sleeve that goes through the steering knuckle you can get rid of as well and go to a metal sleeve. I use the HPI Racing part. I can't remember the part number though. Last edited by Lentsnh2012; 07-04-2013 at 10:27 AM. |
07-04-2013, 02:02 PM | #5 |
Quarry Creeper Join Date: May 2010 Location: scotland
the one thing you can do is get beef tubes then the screw go`s into metal instead of the plastic iam sure a guy on here makes them but i cant remember his username
07-05-2013, 09:42 AM | #6 | |
Newbie Join Date: Jan 2013 Location: Downingtown
| Re: Chub Screw's backing out Quote:
http://www.rccrawler.com/forum/axles...e-updated.html | |
07-05-2013, 12:53 PM | #7 |
Thanks for the heads up... and link |
07-05-2013, 02:07 PM | #8 |
RCC Addict Join Date: Mar 2009 Location: Chilton
Beef tubes are the way to go along with the machine screws. Don't use loctite on plastic it will soften it and eat it over time. Use ca glue when screwing into plastic. I am sure there are people that will disagree with me on using loctite on plastic but they can look it up or keep using it and find out. There are some other threads on here that I have seen people say they won't ever use loctite on plastic again after learning the hard way. Loctite is meant for metal on metal use.
07-05-2013, 02:15 PM | #9 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
+1 on the NO loctite on plastic.. It eats it.. CA glue is the best. It can actually rebuild striped threads. Sent from my highly abused iPhone using Tapatalk |
07-05-2013, 03:33 PM | #10 | |
| Re: Chub Screw's backing out Quote: yep thats the guy | |
Chub Screw's backing out - Similar Threads | ||||
Help me choose the best knuckle and chub | demonoid369 | General Crawlers | 17 | 06-15-2012 08:37 AM |
ID of VP xr10 chub? | Hulksta | Axial XR10 | 2 | 12-01-2011 07:33 PM |
Ax10 chub bushing? | day215 | Axial AX-10 Scorpion | 7 | 08-16-2011 04:50 PM |
