Thread: Chub Screw's backing out
Old 07-04-2013, 10:11 AM   #1
Default Chub Screw's backing out
OK... not the only issue...
as the "C" knuckle screws (kingpins) also seem to loosen/back out
over time used.
Then combined... they create wheel/tire hub slop.
I realize vanquish and others sell alloy parts to replace/improve...
But even with those... the screws would still screw into the plastic axle housing.
* No they're not stripped !
I was told by another that some blue locktite would help keep those seated.
But was worried if those could booger up the insert threads ?
Anyone else have this issue ?
Locktite the temp fix ?
Any issues removing the screw(s) down the road ?
Any other advise regarding ?
TacoCrawler is offline   Reply With Quote
Old 07-04-2013, 10:15 AM   #2
Default Re: Chub Screw's backing out
no my knuckles have an issue with it but my chubs to housing i had no issues after putting blue locktite on my knuckles i need to get some integy kingpins since they seem to be the only one who makes them
mark32 is offline   Reply With Quote
Old 07-04-2013, 10:16 AM   #3
Yeah blue loctite will work well. I've used it in plastic a lot
uclabruins89 is offline   Reply With Quote
Old 07-04-2013, 10:24 AM   #4
Get rid of those woodscrew style screws going into the plastic and pick up the same size in a machined thread. Then, use either blue Locktite or CA Glue to help hold it in the plastic.
The little plastic sleeve that goes through the steering knuckle you can get rid of as well and go to a metal sleeve. I use the HPI Racing part. I can't remember the part number though.
Lentsnh2012 is offline   Reply With Quote
Old 07-04-2013, 02:02 PM   #5
the one thing you can do is get beef tubes then the screw go`s into metal instead of the plastic iam sure a guy on here makes them but i cant remember his username
boohoo is offline   Reply With Quote
Old 07-05-2013, 09:42 AM   #6
Is this the thread you were thinking of?
http://www.rccrawler.com/forum/axles...e-updated.html
maraudriii is offline   Reply With Quote
Old 07-05-2013, 12:53 PM   #7
Thanks for the heads up... and link
Old 07-05-2013, 02:07 PM   #8
Beef tubes are the way to go along with the machine screws. Don't use loctite on plastic it will soften it and eat it over time. Use ca glue when screwing into plastic. I am sure there are people that will disagree with me on using loctite on plastic but they can look it up or keep using it and find out. There are some other threads on here that I have seen people say they won't ever use loctite on plastic again after learning the hard way. Loctite is meant for metal on metal use.
craddock35 is offline   Reply With Quote
Old 07-05-2013, 02:15 PM   #9
+1 on the NO loctite on plastic.. It eats it..
CA glue is the best. It can actually rebuild striped threads.
Sent from my highly abused iPhone using Tapatalk
madkawi650 is offline   Reply With Quote
Old 07-05-2013, 03:33 PM   #10
yep thats the guy
Chub Screw's backing out - Similar Threads
Help me choose the best knuckle and chub demonoid369 General Crawlers 17 06-15-2012 08:37 AM
ID of VP xr10 chub? Hulksta Axial XR10 2 12-01-2011 07:33 PM
Ax10 chub bushing? day215 Axial AX-10 Scorpion 7 08-16-2011 04:50 PM
