08-07-2013, 09:35 PM | #1 |
Rock Stacker Join Date: May 2013 Location: Marietta
| ax30464 install problem
Hey guys, just got my new axial cvd's today. I was wondering if anyone else has had problems with the pivot point of these shafts? It feels like i need to drill out the end that connects to the stub shaft because I literally had to press the cylinder shaped piece in with pliers. Once i got everything together, it was binding like crazy . I don't see any problem with drilling them, just wondered if anyone else had to do this? Thanks |
08-08-2013, 08:32 AM | #2 |
Quarry Creeper Join Date: May 2010 Location: scotland
| Re: ax30464 install problem
i never had todo that mine went in pretty easily but i would suggest changing the pins to something stronger ive managed to break two sets of them. try a guy called gunnar on here he`s selling better pins quite cheaply aswell |
08-08-2013, 04:30 PM | #3 |
Sounds like something is out of spec. You can try to fit them, or contact Axial and they will probably replace them for you. I've had at least 3 sets of these and they always go together very smoothly. It's definitely not normal. |
08-08-2013, 07:21 PM | #4 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| Re: ax30464 install problem |
08-08-2013, 08:31 PM | #5 |
took a 9/64 cobalt bit and cleaned out the holes...worked perfect. If anyone else has this problem, don't try it with anything less than a cobalt or titanium bit. I broke off twice and had to use a punch to knock the broken pieces out.
ax30464 install problem - Similar Threads | ||||
knuckle and c hub install problem | chopan84 | Newbie General | 18 | 09-24-2014 04:26 PM |
winch install problem | kdizz07 | Newbie General | 9 | 07-28-2013 09:40 AM |
Broken CV Pin - ax30464 | SCX10Dingo | Axial SCX-10 | 6 | 07-07-2013 10:32 AM |
Castle Link Install Problem | Knarly Nerd | Electronics | 2 | 06-06-2010 08:51 PM |
Honcho servo install problem | John74_UK | Axial SCX-10 | 24 | 12-23-2009 08:41 PM |
