09-09-2013, 11:35 PM | #1 |
Quarry Creeper Join Date: Oct 2004 Location: Beckley
| Poison spyder bumper issue |
09-10-2013, 05:41 AM | #2 |
RCC Addict Join Date: Feb 2011 Location: York
| Re: Poison spyder bumper issue On the JK there is a post that connects top the main roll cage... |
09-10-2013, 09:00 PM | #3 |
Quarry Creeper Join Date: Jun 2007 Location: east michigan
This is normal of that bumper. Its due to the weight of the spare tire.
09-10-2013, 09:23 PM | #4 |
Since Buster was a dingo how would I attach the upper bar to the body? Also if the upper bar is fixed how does the tire carrier swing out?
09-10-2013, 09:32 PM | #5 |
There is a body clip that attaches the tire mount and keeps the tire from swinging out. Looks like you'll have to get creative to attach it.
09-10-2013, 10:17 PM | #6 |
Rock Stacker Join Date: Dec 2012 Location: SF Bay Area
Have you tried fixing a strong magnet to the inside of the body? Right where the hole of the screw that secures the tire to the carrier would be? Maybe the magnetic force will somehow pull the head of the screw towards the body? Good luck.
09-10-2013, 10:58 PM | #7 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Does your spare have weight in it?
09-10-2013, 11:10 PM | #8 |
I'm going to give the magnet idea a try if I can't come up with a solution to mount an upper bar. And no the spare tire doesn't have weight in it. The plastic wheel that it is on is considerably lighter than the stock bead lock.
09-11-2013, 12:07 AM | #9 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
Looks like I may have the same issue once I get a tire for mine, let us know what you find out. Thanks
09-11-2013, 08:40 AM | #10 |
Quarry Creeper Join Date: Jun 2013 Location: Canada
| Re: Poison spyder bumper issue |
09-11-2013, 08:47 AM | #11 |
09-11-2013, 09:54 AM | #12 |
Thanks for posting that, it puts my mind at ease. Mine is the Poison Spyder bumper mount
09-11-2013, 09:56 AM | #13 |
I hope you guys have all the luck with just the JK mount but I know on my JK's that when the clip was out, the carrier would sag down. A big contributor to the thicker bumper mount is that it's set up to accept an Anti-Sway bar.
09-11-2013, 10:44 AM | #14 |
Pebble Pounder Join Date: Aug 2013 Location: If assholes could fly this place would be a airport
mine does that but when you clip it to the cage it holds it upright...
09-11-2013, 11:42 AM | #15 |
The Vanquish SCX10 JK Rear bumper mount solves the problem of the bumper mount twisting from the weight of the spare tire. Axial SCX / JK Rear Bumper mount Black |
09-11-2013, 03:05 PM | #16 |
It's not really the bumper mount flexing, its the spare mount flexing.
09-11-2013, 04:13 PM | #17 |
I just change the amount out to the poison spyder unit and it is still flexing. I am going to have to figure out how to attach the upper tire mount to the body. Unfortunately the magnet idea was not strong enough to hold the tire in place. Any ideas for a removable brace so that the tire carrier can still open?
09-11-2013, 04:36 PM | #18 |
Quarry Creeper Join Date: Nov 2011 Location: San Diego
You could try running a longer screw through the body into the spare mount which hold the tire on. Then to get the boddy off just unscrew the tire mount wingnut and slide it out.
09-11-2013, 07:28 PM | #19 |
You could also try to brace it with some aluminum. just trying to think outside the box.
09-11-2013, 08:36 PM | #20 |
| Re: Poison spyder bumper issue I had an aluminum brace on my last swing out tire carrier. It ran from the rear bumper crossmember to the bumper itself. It was strong but my only complaint was that it look out of place. Plus I'm leary of drilling into that new bumper that just came out of the package. I have been working on the magnet idea and may have it working now. I need to take Buster out and test the strength of the magnet before I call it a success. Any other ideas about a brace would be greatly appreciated.
Poison spyder bumper issue - Similar Threads | ||||
Axial Poison Spyder Bumper Sets IN STOCK!! | RPP Hobby | RPP Hobby | 2 | 01-12-2013 09:23 PM |
Axial SCX10 Poison Spyder Brawler Lite Front Bumper | BENDER | Scale Accessories | 8 | 11-29-2012 02:52 AM |
Axial SCX10 Poison Spyder Brawler Lite Front Bumper | BENDER | Axial SCX-10 | 0 | 11-15-2012 12:09 PM |
