Thread: Im going to do it again.
Old 09-09-2013, 12:41 AM   #1
Default Im going to do it again.
Today I picked up a running driving dingo to be become my boys first axial. I will be giving this to my boy for his 9th birthday gift. My plan is to pull every thing apart and clean the chassis and overhaul the drivetrain. Change the wheelbase from 11.4 to 12.2. I may Chang the motor from a 20 turn to a 35 turn to slow it down. I will be adding a set of Pro Line Interco TSL SX Super Swamper 1.9 tires in G8 compound. I will also be adding a set of JunFac Carbon Steel drive shafts to the mix. To top this small build off I will be adding a Pro Line 1980 Chevy Pick-up body. I want to thank a good friend rcpilotjr for this rig. This is the link to his build up of this rig to date.Rcpilotjr's Dingo
Current Setup
Body-Stock Dingo
Axles-Stock
Ring/Pinion-Stock-38t/13t
Pinion/Spur-13t/93t
Drive Shafts-Stock WB8
Tires-RC4WD Rock Crusher X/T 1.9
Wheels-Axial 8 Hole BL
Motor-Duratrax Photon Speed 20T Brushed
Esc-LiPo Tazer 15T WP
Servo-Hitec HS646WP
Batteries-2S/7.4 LiPo 5000mAh
Shocks-Stock With 30WT Oil with 1/2 Bumpstops
Front Springs-Super Soft Main/Super Soft Secondary
Rear Springs-Super Soft Main/Super Soft Secondary
Front Suspension-3-Link w/ Stainless Tube
Rear Suspension-4-Link w/ Stainless Tube
greengoblin is offline   Reply With Quote
Old 09-09-2013, 05:44 PM   #2
Default Re: Im going to do it again.
You're an great Dad,my friend ,sounds like a cool project,he'll love it (trust me,he will. My boy loved my Ridgecrest so much it became his too,LOL )
The DC is offline   Reply With Quote
Old 09-10-2013, 05:04 PM   #3
Thanks its just me and him so i do every thing i can for my boy.
Old 09-10-2013, 05:19 PM   #4
Up Date
I spent some time on the build last night. I pulled the old wheels and tires of the truck to clean the wheels. After cleaning the wheels with 409 then letting the wheels sit in hot soapy water all night. Success!! Well guys and gals I will just show you photo time.
Old wheels and tires
After cleaning
Old 09-11-2013, 06:09 PM   #5
Up Date
I mounted 2 of the super swamper tsl sx's. I used the new bead lock rings I had on hand.
Interco TSL SX Super Swamper 1.9" G8 Rock Terrain Truck Tires Product ID: 1163-14
Old 09-11-2013, 08:05 PM   #6
Love those swampers.. Really soft and bite well
MoonyJohn is offline   Reply With Quote
Old 09-19-2013, 07:20 PM   #7
Up Date
I have removed front and rear axles from the truck and swapped in a new set of axles. The front axle has received a set of Axial aluminum c hubs and knuckles. I removed the front plastic 3 link and added a front 4 link. I used the Axial 6x91 aluminum tube for the front and the rear. I all so replaced the rear links with Axial 6x106 aluminum tube.The next thing I will me doing is working on the C.M.S. to move the servo up and out of the way. I have already completed this mod to my old school project. Sorry I did not take photos of that mod. I will post before and after photos of the C.M.S. at a later time.
Old 3 link set up
Old front axle
Now for the new
Old 09-28-2013, 11:51 AM   #8
Up Date
I placed the order for the Pro Line 1980 Chevy Pick Up Body and the junfac hardened carbon steel drive shafts. I finished building the drag link for the C.M.S. I am now in the process of cleaning the frame and painting any spots needed.
C.M.S. photos
Before The cleaning .
Old 10-02-2013, 08:57 PM   #9
Up Date
I placed the order for the body last week. It came in today now to hide it so the kid can not fined it. This is where the truck is at this point frame painted and cleaned.
Old 10-04-2013, 07:58 PM   #10
Up Date
Well the body has been trimed and mounted to the truck. I put the dingo fender flares on to.
Old 10-04-2013, 10:51 PM   #11
Lookin good! Got a lucky kid! My sons got a honcho lol
Arnel is offline   Reply With Quote
Old 10-22-2013, 06:19 AM   #12
Up Date
I received the junfac shafts today.
Old 10-22-2013, 08:25 PM   #13
i here there good shafts
Deadpool is offline   Reply With Quote
Old 11-03-2013, 05:14 PM   #14
Up Date
I got some time to work on the project this weekend.
Old 11-04-2013, 06:12 PM   #15
Up Date
Body meats its new home. I took the rig out side and took a few photos. I still need to fab up a battery tray to finish the truck for my boy.
Old 11-11-2013, 05:03 PM   #16
Up Date
Ok guys I did a small cheap cosmetic up grade. I changed all the outside screws in the beed lock to a stainless screws.
Old 11-11-2013, 05:36 PM   #17
Love the paint man, I'm sure he'll enjoy it! Thinking about the TSL's as well for my honcho!
preto789 is offline   Reply With Quote
Old 11-17-2013, 09:56 PM   #18
Up Date
Well everyone this build is almost at its end. I built the battery tray and Esc mount this weekend. They have been painted the same color as the body and mounted to the truck. A friend of mine let me get his honcho box so now I need to wrap it up and let him have it.
Esc mount
Battery tray
Getting some flex on
Old 11-17-2013, 10:43 PM   #19
looks good
OGXXXOG is offline   Reply With Quote
Old 11-17-2013, 11:57 PM   #20
Originally Posted by greengoblin View Post
Today I picked up a running driving dingo to be become my boys first axial. I will be giving this to my boy for his 9th birthday gift. My plan is to pull every thing apart and clean the chassis and overhaul the drivetrain. Change the wheel base from 11.2 to 12.2. I may Chang the motor from a 20 turn to a 35 turn to slow it down. I will be adding a set of Pro Line Interco TSL SX Super Swamper 1.9 tires in G8 compound. I will also be adding a set of JunFac Carbon Steel drive shafts to the mix. To top this small build off I will be adding a Pro Line 1980 Chevy Pick-up body. I want to thank a good friend rcpilotjr for this rig. This is the link to his build up of this rig to date.
Fairly sure the factory established wheel base is
either 11.4" or 12.3" respectively.
^ just noting so that others aren't misinformed.
Build looks great !
Yer little one should be very happy !
TacoCrawler is offline   Reply With Quote
