11-11-2013, 07:12 PM | #1 |
| Testing Interest ~ Flip Your Lid!
I built these when I first got my Honcho and they've held up just fine. It was a pita to unplug my lights every time I took the lid off. Thought it might be a good product for Eyeball Engineering to offer up to you guys. What is pictured are prototypes...the production version will be a bit more streamlined and won't require any modification of the frame. The only body clips required are the ones on the hood. Thoughts? Last edited by Duuuuuuuude; 11-11-2013 at 07:15 PM. |
11-11-2013, 07:21 PM | #2 |
| Re: Testing Interest ~ Flip Your Lid!
I like that idea alot, very cool!
11-11-2013, 07:29 PM | #3 |
Newbie Join Date: Nov 2013 Location: Olive Branch
Great idea rear body clips suck period on the honcho.. got any idea on price point yet? That would probably make or break this idea.
11-11-2013, 07:31 PM | #4 |
| Re: Testing Interest ~ Flip Your Lid! |
11-11-2013, 07:43 PM | #5 |
keep us updated. I was going to figure out a jerry rig to do it.. but if you can keep it looking that clean I'm in.
11-11-2013, 07:46 PM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
I would def take a set or two, my ace hardware hinge leaves a bit to be desired.
11-11-2013, 07:59 PM | #7 |
This is probably what the production version will look like. Channeled to fit over the frame, bolted on using the existing bolt for the rear light buckets. |
11-11-2013, 08:04 PM | #8 |
Any cons you've seen so far? Other than unbolting it to take the body all the way off to clean it ect? Also where are you at in Arkansas?
11-11-2013, 08:05 PM | #9 |
11-11-2013, 08:27 PM | #10 |
^ LOL my Honcho is a rock/pavement queen of sorts until she gets fully waterproofed! I've detailed it twice and only had it a week.. Anyway sounds good. PM me a price when you can get a finished product out with shipping (38654)? I'm in North West MS near TN Line (next to Memphis, Tn) didn't know how close ya were. |
11-11-2013, 08:37 PM | #11 |
cool... but yer gonna need some clamping collars or something... to keep the cage tubing from wandering left-right on those pivots. I'd likely buy a coupla' pair... if the price were right... and the cage assembly could not shift. |
11-11-2013, 09:00 PM | #12 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Excellent piece duuuuuuuuude!
11-11-2013, 09:21 PM | #13 | |
| Re: Testing Interest ~ Flip Your Lid! Quote:
Collars are not a bad idea though. | |
11-11-2013, 09:49 PM | #14 |
That's a neat idea. If you made a simple cross bar that an already existing body post system could be attached to you'd have a winner for those without a honcho tube bed as well.
11-11-2013, 09:57 PM | #15 | |
Maybe just some plastic cylinders measured/cut to the correct length so that it spaces both sides equally ? ^ would be cheaper to do | |
11-11-2013, 10:08 PM | #16 |
| Re: Testing Interest ~ Flip Your Lid! I was thinking about delrin tubing. Can't get it in black without being 1/2" od though. Might have to try abs or something.
11-11-2013, 10:29 PM | #17 | |
Think the cage tubing is about 7mm in diameter. Maybe 1/4" fuel tubing could be used and stretched a little to fit, if need be ? ^ little dish soap and water helps | |
11-11-2013, 10:58 PM | #18 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
are you going to make the flip up body mounts in aluminum, if so how much.
11-11-2013, 10:59 PM | #19 |
11-11-2013, 11:12 PM | #20 |
what kind of plastic is that machined from ? delrin ? I'm ok with the lower price... alloy is prolly overkill anyhow. |
Testing Interest ~ Flip Your Lid! - Similar Threads | ||||
Testing interest ~ D-Mount for the LCC | Duuuuuuuude | Team Losi Comp Crawler | 39 | 07-19-2013 08:58 PM |
Testing Interest ~ AR60 D-mount | Duuuuuuuude | Axial Wraith | 20 | 12-21-2012 11:10 PM |
Testing Interest ~ AR60 D-mount | Duuuuuuuude | Axial AX10 2nd-gen | 37 | 12-21-2012 05:10 PM |
Testing Interest ~ AR60 D-mount | Duuuuuuuude | Axial AX-10 Scorpion | 33 | 12-19-2012 04:54 PM |
My newest new lid, 2010 comp lid | slowngreen | Paint and Body | 10 | 04-13-2010 04:34 PM |
