12-11-2013, 07:37 AM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: Emmaus, Pa
| a little motor clearance problem
So I ran into a little issue. I'm running a mabuchi and the cans are a little long. Right where the top link attaches to the chassis is where the back of the can stops. I cannot run bigger than a 14 tooth bc the motor hits the link. Any ideas? |
12-11-2013, 07:44 AM | #2 |
| Re: a little motor clearance problem
It looks like there is plenty of clearance. You can run any size pinion you want. You just need to run the appropriate size spur to accommodate it.
12-11-2013, 07:46 AM | #3 |
The obvious choice would be to get a different motor. If you are just trying to get more wheelspeed, try adjusting the spur gear size as well. You can go all the way down to about 80/20 and still maintain maximum clearance on the chassis side.
12-11-2013, 07:49 AM | #4 |
Quarry Creeper Join Date: May 2010 Location: scotland
i run the same motors with a 18t or 19t pinion with no problems. here`s mine runnign a axial motor at the moment which is roughly the same length Last edited by boohoo; 12-11-2013 at 08:01 AM. |
12-11-2013, 07:59 AM | #5 |
Duh didn't think about droppin the spur. I'm an idiot sometimes, thanks guys.
a little motor clearance problem - Similar Threads | ||||
quick fix for motor clearance | redcat1 | Redcat Crawlers | 6 | 02-25-2012 06:56 PM |
Motor clearance? | Chaos314 | Team Losi Comp Crawler | 4 | 07-09-2010 12:41 AM |
motor Clearance????? | 2.5TonK5 | Electronics | 3 | 06-24-2008 04:43 PM |
Clod Motor-Wheel Clearance | DKNguyen | Tamiya Clod Buster | 1 | 10-08-2007 05:33 PM |
Stealth Clearance Problem/ spur gear size? | blue-beard | Newbie General | 15 | 06-26-2006 09:20 AM |
