12-24-2013, 06:14 PM | #1 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Inside 6sharky9's SCX10 Honcho RTR
If you've read my STOCK SCX10 performance thread Stock SCX10 Performance Tech. then you've seen what ive done to my truck..But heres a more indepth look at how ive taken it farther with some bolt ons Holmes Hobbies BR-XL ESC Custom Trinity 27T mod motor. Trinity EA motorsports 27T armature inside trinity experimental mod can...6 degrees advanced timing..Silver brushes, purple springs. GensAce 4800Mah (25c) 2s saddle pack lipo. (Deans battery connectors) Hitec HS985MG Servo (177oz./in. Torque at 6.0V) Specktrum DX 3.0 Radio and SR-3001 receiver Some added Upgrades: Level3 Rear aluminum 4 link truss Level3 Front aluminum 4 link truss 3Racing Motor heat sink STRC aluminum heat sink Motor plate Robinson 16T lightweight motor pinion Kimbrough 87T 48 pitch spur gear HR Aluminum servo mounts Axial 8 hole 1.9 beadlock wheels GPM lower steering link Integy Front Universal Axles Axial HD 43/13 rear gear set (Under Drive) Axial HD 38/13 front gear set (stock ratio) Locked Up F.I. spools front and rear Losi comp 4 inch shocks..(limited to 93mm/Losi White 1.8lb springs/30wt oil/custom piston work) Home made upper and lower suspension links and upper drag link. Converted to 4 link ( front ) Aluminum front bumper mount Home Made upper shock mount extensions. Home Made Anti squat Rear upper link brackets. Fully balanced front to rear left to right. (Selection of tires so far) Axial 1.9 Ripsaws (came with rtr Honcho) Axial 1.9 Trepadors (came with rtr Rubicon) Proline 1.9 Flat-Irons (got in trade) (Whats in the future for upgrades???) Beef Tubes (front and rear) Locked up OT2 rear axles Locked up Slipper eliminator kit Pitbull Rockbeast 1.9 tires Crawler Innovations Tire Foams Aluminum rear bumper mount Proline F250 Body (truggy) Adding scale items Last edited by 6sharky9; 04-27-2014 at 02:02 PM. |
12-26-2013, 09:19 PM | #2 |
| Re: Inside 6sharky9's SCX10 Honcho RTR
Just sold my Proboat blackjack 26ss so more goodies on the way off the list. |
12-31-2013, 12:26 AM | #3 |
So I played around a little with Microsoft paint and think this may end up what I may do in the looks department with the RTR Toyota body for fun. |
12-31-2013, 03:06 PM | #4 |
Ordered a level3 truss for the front like I have on the rear to complete the matched pair.
01-02-2014, 07:12 PM | #5 |
So im looking over the front stock 4 link truss and how close it is to the servo plate...A problem im thinking I will have is the Level3 truss where the links mount are a bit taller and im thinking I may have installation issues without making some changes...Guess ill be figuring something out when I get the truss..I maybe should've gotten the wide angle truss for the front and actually it wouldn't be a bad idea to get those for the rear as well...They mount the links lower and wider apart..Im thinking lower CG and more capable geometry.
01-02-2014, 11:07 PM | #6 |
My son is utilizing the level3 (wide, low profile) four link mount at the rear. Mostly 'cause... it only requires use of the two holes at the axle's center chunk for mounting. an added benefit... is more overhead clearance then many other link mounts being offered. ^ including the level3, HR and Axial standard 4 link mount designs (prolly more). The son is rolling a Mojave Hilux body (full bed) So the rear upper shock hoops are removed... and his Rr. shocks are positioned like so / \ ^ ( homebrew gearhead design ) The wider, lower profile level3 link mount... seems to help reduce chassis roll somewhat. Tho' improved... it's still not good enough for me. ( I'm never satisfied ) but the son thinks it's better then what it was. It's his junk... so it's his call. ^ I'm trying to get him interested in doing a cantilever set up instead but he's kinda hard headed and/or lazy like many young adults are I think that when utilizing the wider level3 4 link mount the wider spacing of the links at the axle side... helps with reducing chassis roll. But I have not tried the level3 4 link mount on my junk... So I cannot say for fact what effect might occur. So if you go that route... do tell us what you find out !? Last edited by TacoCrawler; 01-02-2014 at 11:20 PM. |
01-02-2014, 11:26 PM | #7 | |
| Re: Inside 6sharky9's SCX10 Honcho RTR Quote:
01-05-2014, 02:54 AM | #8 |
Received the truss today and will see how it may or may not fit soon..lol |
01-05-2014, 05:42 AM | #9 |
Well its definitely too tall to fit under the axle mounted servo assembly so its not going to make its way onto the truck...For those buying these trusses make sure you get the low mount versions as the tall ones only work for the rear apparently...Ill just be ordering the low mount versions for the front and the rear...Bummer. The only way to make it work would be to raise the servo plate about 1 inch and im not wanting to do that to get it to fit. Last edited by 6sharky9; 01-05-2014 at 05:46 AM. |
01-05-2014, 07:52 PM | #10 |
Pebble Pounder Join Date: Jul 2013 Location: Colorado Springs
I don't see a reason to run a bumper much less a full width rear bumper on a honcho... Just looks odd..
01-05-2014, 09:02 PM | #11 |
| Re: Inside 6sharky9's SCX10 Honcho RTR |
01-20-2014, 04:51 PM | #12 |
Im officially on a list to receive 2 Locked up FI spools once they are back in stock and have some Axial HD 38/13 and 43/13 ring and pinion gears on the way to add to the Honcho.
02-02-2014, 06:52 PM | #13 |
Ive received my Axial HD gears about a week ago but still waiting for the Locked up FI spools that were on backorder to show up so I can install everything...Hopefully this upcoming week I get them. This is whats left in the plans for the Honcho: Level3 Low profile trusses for the front and rear. Locked Up Slipper eliminator kit Pitbull Rockbeast Tires and foams (1.9) Aluminum rear bumper mount Proline F250 Truggy body Maybe some scale items for looks. Last edited by 6sharky9; 02-02-2014 at 07:37 PM. |
02-04-2014, 09:42 PM | #14 |
Pebble Pounder Join Date: Aug 2013 Location: San Jose
Thanks for the information you have posted...it helped me tweak my Dingo/Defender. I am running level3 CMs on it and initially kept rolling over even on not too steep of a terrain. I did some adjustments, cut off rear cross brace, removed 8 AA battery pack in rear (forLED) lights and made a huge improvement overall. I'm actually very happy pretty impressed with its performance. On my SCX10 rubicon kit, I am running the Level3 lower alum 4link truss mounts front and rear and am very happy with them. Thank you on both of your threads as it is helping me set up my trucks! Oh...and I'm planning on biting the bullet on getting 2 sets of the Beef Tubes for both front axles of my 2 SCX10s for better low COG added weight. What do you think? Sent from my iPad using Tapatalk - now Free Last edited by eunique; 02-04-2014 at 09:45 PM. |
02-05-2014, 01:23 AM | #15 | |
I would say beef tubes would more help with the more powerful setups..Not that its a bad thing to get some but its not really something that would be considered a must have..I guess its based on how you are going to treat your truck..Most who compete usually use them as a piece of mind but its not that stock housings break or don't work under normal or some harder use without them..basicly if you want it and it makes you happy then go for it...It will require some mods to fit them so be ready to do some grinding if you do. EDIT: If anything look at it as you'll be adding weight in the best area you can to help with traction and center of gravity should you decide to get them. Last edited by 6sharky9; 02-05-2014 at 04:19 AM. | |
02-05-2014, 01:58 AM | #16 |
For those who couldn't see the pics, they seem to be back up.
02-05-2014, 02:40 AM | #17 |
02-05-2014, 03:18 AM | #18 |
Heres a better one..figure out the angle |
02-07-2014, 09:17 AM | #19 |
Downloaded an app on to my phone to get the angle above and it measures out to 54.6 degrees...Im pretty happy with that. Now to test the vertical range. Last edited by 6sharky9; 02-07-2014 at 09:23 AM. |
02-07-2014, 09:25 AM | #20 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Inside 6sharky9's SCX10 Honcho RTR - Similar Threads | ||||
New guy, SCX10 Honcho RTR, a few questions about my Honcho | dan188 | Axial SCX-10 | 2 | 10-04-2013 09:43 AM |
