01-09-2014, 02:10 PM | #21 |
| Re: High steer angle (bent) steering link ? That looks like steel? BTA steering might work with that on the SCX? I used Blue Monkey Tie rod, VP straight ti link (forget the length, but not stock) with Axial aluminum chubs and high steer knuckles...works great on my SCX. That is what I used, but substituted custom length draglink and lessened the bends at the end of the drag link to keep it tighter in close to the axle. I also run toe out for better steering and the shocks rubbing is what limits me. Last edited by Natedog; 01-09-2014 at 02:14 PM. |
01-09-2014, 02:58 PM | #22 | |
| Re: High steer angle (bent) steering link ? Quote:
might work but I have no knowledge. I set my toe slightly positive ('bout .5mm) I often let go of the TX's wheel when traveling straight forward and don't like the chassis tracking (wandering) left or right. .5mm improves the straight line tracking ability and I don't really notice any decrease in L/R steering input nor response. Last edited by TacoCrawler; 01-09-2014 at 03:06 PM. | |
01-09-2014, 06:00 PM | #23 |
In the band for now. Join Date: Sep 2012 Location: roselle
[QUOTE=6sharky9 Look up the traxxas 5347 rod ends..Best traxxas has..8-9 dollars for a set of 12 I think...I use those on all my home made links. They aren't for little puny 3mm threads though[/QUOTE] I use them on all my rigs (3mm) and have yet to break or bend one. seems mr guppy isn't as smart s he thinks he is you give way to much bad advice, stick to what you know which isn't much |
01-09-2014, 06:33 PM | #24 |
I use the Traxxas # 1942 rod ends... kit comes with 16 long and 4 short ends plus 18 steel hollow pivot balls. was $ 6.99 at my LHS ^ These measure 10mm from shank end to ball center. and are very close to what the original Axial ends measure. I think the Traxxas part# 5347 listed above is for the Revo rod ends. But don't bet yer life on that. I do know the Revo ends are much longer then the original Axial link rod ends. And would require shorter link rods to keep the wheel base near what it was originally. |
01-09-2014, 07:04 PM | #25 | |||
WIth my toe out and proper servo/steering centering I get no wandering from SCX while driving high speed straight line...and I get more steering this way. Quote:
01-09-2014, 09:33 PM | #26 | ||
It's solid core 4mm alloy But no doubt... it could still get bent. But the same can be said for any other metal link rod too. Even titanium has its limits. (but costs a lot more) Quote:
I knew that... but forgot to mention that. Last edited by TacoCrawler; 01-09-2014 at 09:36 PM. | ||
01-13-2014, 10:03 AM | #27 | |
03-14-2014, 09:01 PM | #28 |
Newbie Join Date: Aug 2011 Location: Pittsburgh
| Re: High steer angle (bent) steering link ? |
03-15-2014, 04:03 PM | #29 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
You know the cheaper way would have been getting angled rod ends. Just messing with you. But thats what I did with mine. I really like the link you went with I might nab me some for my SCX10 and AX10. |
03-16-2014, 12:06 AM | #30 |
05-21-2015, 07:25 PM | #31 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Sorry for not replying a year ago....LOL. I am using Gear Head 1.9 Trail King EZ Locs. Gear Head RC 1.9 Trail King EZ-Loc Wheels (4) |
05-22-2015, 12:06 AM | #32 |
It's been a year now ? welp... just updating my experience with it. My RC4WD Gelande2 tie rod link has taken all of the abuse I could throw at it. Including a few serious tumbles off a 20-30 ft rock. It did get bent a few times... but I was able to simply bend it back to it's original form by hand. It does not bend or flex under normal steering/use... only when it tumbles or falls off a big rock and lands badly. I would have thought re-straightening it would have caused weakness/failure after several attempts of doing that. But that hasn't happened to date. It still functions good and looks swell doing it. I purchased a spare/replacement just in case... But I have never needed to install it. yet anyways. I like the scale look of the thinner steering link tubes... the 1/4" or 6mm steering link rods look less then scale IMO I just wish I could find a thinner servo link rod as well. but for some reason that has eluded me. To sum it all up... I have no regrets in running the Gelande 2 steering link. 'cept maybe paying $ 8.00 for them. Last edited by TacoCrawler; 05-22-2015 at 12:09 AM. |
05-22-2015, 03:00 PM | #33 |
TacoCrawler, thanks for update. My Blue Monkey tie-rod has not bent at all including much abuse...only a slight rock rash on it. |
High steer angle (bent) steering link ? - Similar Threads | ||||
setting up steering link with high steer | m1009cucv | Axial SCX-10 | 3 | 07-15-2013 09:12 AM |
VP high steer knuckles/drag link steering set up | SCORPIAN670 | Axial AX-10 Scorpion | 6 | 11-30-2009 02:10 PM |
Will Vanquish Axial High Steer Steering Knuckles make my truck steer tighter? | blue bronco | Axial AX-10 Scorpion | 3 | 08-09-2009 12:30 AM |
