Thread: Scx10 Mirror Transmission mod
Old 12-29-2013, 09:32 PM   #1
Default Scx10 Mirror Transmission mod
How to How to Mirror your scx10 Transmission. This mod helps with torque twist when on a incline. Sorry for the video quality as im moving my work workbench so my kids desk made do for the time being.
greengoblin is offline   Reply With Quote
Old 01-03-2014, 10:10 PM   #2
Default Re: Scx10 Mirror Transmission mod
Thank you for posting this. Just completed it on mine per your video
SirKarnage is offline   Reply With Quote
Old 01-04-2014, 07:44 AM   #3
I asked him the other day how to mirror a transmission, then he sends me this video link. It helped me out a lot when I mirrored mine. Still don't have my esc though....
john79lewis is offline   Reply With Quote
Old 01-04-2014, 11:06 AM   #4
I was able to follow along and have but one suggestion. The only additional hardware removal needed to flip the transmission mounting plate are the two rear shock hoop screws and one rear bumper plate screw on either side. With those out you can spread the frame rails sufficiently to remove the tranny plate and flip it around. No need to remove the shocks or any of the front end hardware.
CBR74 is offline   Reply With Quote
Old 01-04-2014, 12:59 PM   #5
Just did mine......oh snap I cant use the gear cover....
racer is offline   Reply With Quote
Old 01-04-2014, 01:58 PM   #6
So on the truck, you used the green spacers instead of the plastics from the parts tree?
skeelo is offline   Reply With Quote
Old 01-04-2014, 06:12 PM   #7
I was just looking mine over again, being concerned with wiring getting into the spur teeth. Can the back and gear cover still work? What will the issue be?
Sent via Pocket Command
Old 01-04-2014, 06:47 PM   #8
you cant use the spur cover because you took off the mounting plate for it. you might be able to rig up something though.
Old 01-04-2014, 06:58 PM   #9
Yes, what I referred to as the "back" plate. Can that not be put back on as well? I guess I don't see the issue it "looks" like it would work, but if it would work I also think why wouldn't people have done that to begin with. I'm new lol and now my head hurts thinking about it.
Old 01-04-2014, 07:15 PM   #10
The easy way to know it's mirrored is the "axial" on the aluminum motor plated faces in to the tranny. Afaik because of the molded spacers on the motor plate with the gear cover, it can't be mirrored. But don't quote me on that as I've only dealt with one on my kid's rig. For years there were no gear covers available to stop from munching wires, zip ties for wires near moving parts work wonders.
Meatwad is offline   Reply With Quote
Old 01-04-2014, 08:29 PM   #11
The green spacers are the same as the one from the parts tree. They were left over parts i had from a ax10
Old 01-04-2014, 08:35 PM   #12
The spur cover back plate cant be used because it can not be flipped over to go on the back of the Transmission. I have never had any wiring get into my spur my battery is up front.
Old 01-05-2014, 02:17 PM   #13
Just a suggestion, but you can also just unbolt the skid and swap it around, putting the spur forward. This does the same thing with moving the motor to the right side of the chassis.
This is a mod that is probably as old as the AX-10 kit itself.
JesterSpec is offline   Reply With Quote
Old 01-05-2014, 02:34 PM   #14
In this case the motor will be to the right but behind the skid, the idea of the mirrored mod is to put the motor forward and to the right. Trying to lessen the effects of torque twist by putting a majority of the necessary bulk to the front passenger side.
Old 01-05-2014, 06:09 PM   #15
I fully understand that.
Less than an inch of a bonus with a lot more work.
Old 01-05-2014, 06:42 PM   #16
Rebuilding the trans isn't so hard, a few screws and about 30mins
Old 01-06-2014, 04:59 AM   #17
If you do that you change the Weight distribution of your truck.
Scx10 Mirror Transmission mod - Similar Threads
Mirror Imaged Transmission EeePee Axial AX-10 Scorpion 174 11-27-2017 03:07 PM
mirror a scx10 transmission??? tmaxxman80 Axial SCX-10 9 05-05-2013 08:50 AM
How to mirror a transmission? Tourettic1 Newbie General 3 11-09-2012 08:41 PM
Transmission Mirror help! ieatfish Axial SCX-10 2 03-17-2012 12:56 AM
