Thread: proline scaler shock shaft replacement
Old 01-11-2014, 05:25 PM   #1
Default proline scaler shock shaft replacement
So one of my shafts for my scaler shocks is slightly bent. Not really a visible bend but just enough so that the shaft up and down is tight when the bottom cap is screwed all the way on. I have tried other o-rings, use green slime, all the other ones build fine, but this one shaft is tight. Switched shafts with another scaler shock, still its tight in another body/o-rings.
Anyone know where to get replacement shafts without buying more of the shocks?
uclabruins89 is offline   Reply With Quote
Old 01-11-2014, 06:08 PM   #2
Default Re: proline scaler shock shaft replacement
Update: turns out one of the bottom caps is bad. Whichever shock i put it on becomes tight when the cap is tightened down. Gonna try to file the little hole a little and see if it gets better
Old 01-11-2014, 08:31 PM   #3
From the Proline website:
"For replacement components to your PowerStroke shocks please call Pro-Line customer service at 1-800-899-RACE (7223)"
k7zpj is offline   Reply With Quote
proline scaler shock shaft replacement - Similar Threads
Replacement shaft suggestions! genki Tamiya CR-01 28 05-16-2008 07:49 PM
Replacement output shaft. mrwonderful General Crawlers 4 07-31-2006 07:39 PM
