Thread: Started my summit tranny,brushless, wraith axle build tonight
Old 01-12-2014, 08:34 PM   #1
Default Started my summit tranny,brushless, wraith axle build tonight
Well i was bored amd decided to start building my scx. I a, using my wraith axles as mock up while i wait on new trans gears. Wraith lasted 15 mins with a tekin roc 412 and mamba max pro set up. Lol so i got the arms and shocks mount. I still need to make new uppers to correct the pinion angle. I just drilled out the stock wraith driveshafts with a 15/64ths bit to match the summit trans. The motor set ip for scx is a timbuk2 with ballastic 18.5 and will be on 2s lipo. Gotta order new axles still and 3 channel radio. Well let me know what you all think so far.
jeeping99tj is offline   Reply With Quote
Old 01-12-2014, 08:36 PM   #2
Default Re: Started my summit tranny,brushless, wraith axle build tonight
Old 01-12-2014, 08:36 PM   #3
Old 01-12-2014, 08:43 PM   #4
Old 01-12-2014, 08:44 PM   #5
Front towers on
Old 01-12-2014, 08:46 PM   #6
Well thats all for tonight. Will try on it tom.
Old 01-14-2014, 11:39 AM   #7
You in time created a subject. I want put to my scx10 a reducer from E-savage. It is possible to photograph how links fastening is made?
Dimonio is offline   Reply With Quote
Old 01-14-2014, 12:34 PM   #8
Which links u talking about ? I am making my upper links tonight and modify front drive shaft.
Old 01-14-2014, 01:09 PM   #9
Fastening of the top links remains former? And lower links as will fasten?
Old 01-15-2014, 08:09 PM   #10
Old 01-15-2014, 08:10 PM   #11
Old 01-15-2014, 08:16 PM   #12
Need a body and make backet for trans servo. Running tekin roc 412. Waiting on pinion gear to show up so i can test it. I extented front a bit while making the arms. Hope i like it.
Old 01-17-2014, 05:16 PM   #13
Well i got it going and i love this thing. 1st crawls so nice tons of tq. And 2nd gear rips. Wheelies with ease shoukd be fun on hill shoots. I broke pin in stock wraith driveshaft so i went to slot and wing and got this 4 dollar body and some mip shafts. The shafts were all in boxes amd had to make some but only paid 25 bucks. Love that place. Cant wait till snow melts to reallly play on some hills.
Started my summit tranny,brushless, wraith axle build tonight - Similar Threads
Scx10 chassis an wraith motor/tranny axle question 07trd4x4 Axial SCX-10 10 05-06-2012 10:18 PM
Just gettin started you guys like the Summit jeepit General Crawlers 12 01-29-2009 10:54 AM
Custom Build **Using Stock AX10 Axle and Tranny Kit** Rockpiledriver Axial AX-10 Scorpion 7 12-07-2008 12:08 AM
