01-20-2014, 08:46 AM | #1 |
Pebble Pounder Join Date: Aug 2007 Location: South Central Mississippi
| Use stock rims and install lead weights or??
I'm building my SCX kit and bought plenty lead weights to install in the wheels. I got the Great Planes self adhesive weights. 1. First off, should I put weights around the wheel? If so, how much and what's the best epoxy or method to hold them around center of wheel. 2. Should I not install weights? Why? 3. I started to order the 8 hole beadlocks but didn't. Was thinking in the future of getting heavier rims and new tire set to swap back and forth with. 4. I star cut my foams on my AX10 build years ago. Is this still the way to cut newer foams today? Even the SCX stock foams? Thanks for educated opinions! |
01-20-2014, 08:54 AM | #2 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Use stock rims and install lead weights or?? Quote:
IF you have self adhesive backed weight you don't need anything else to mount them..If they are 1/4oz weights you can install a max of 3.5oz of weight per wheel..You will have a small gap between the full radius but center the last weight between the gap ...You don't have to add that much weight however..just evenly space out what you want to add and it will help you get some much needed traction..Its common to add more to the front than the rear or just weight on the front only..just see what you like...Again easy to do with beadlocks as you may have to take tires off a few times to get it right. You can still cut the foams but technology has advanced and you can get better performing foams without cutting...Check out Crawler Innovations in the vendors section...talk to him and he will recommend a set of foams to suit your need. Last edited by 6sharky9; 01-20-2014 at 08:56 AM. | |
01-20-2014, 09:08 AM | #3 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
I weighted my stock wheels with self adhesive weights then wraped a couple layers of eletrical tape around them to ensure they didn't come in stuck. Then I switched to bead locks since I hate having to glue tires. |
01-20-2014, 09:29 AM | #4 |
Quarry Creeper Join Date: May 2013 Location: on top of the rocks
I usually take one of my crawlers to the local tire store and ask if I can buy some stick on wheel weights. I show them the new tires and wheels and they think its cool. Most of the time they give me 4-6 sticks for free,I've even got one of their managers into crawling. I like their wheel weights because they are painted and don't stain or deteiorate my foams.
01-20-2014, 10:28 AM | #5 |
Quarry Creeper Join Date: May 2012 Location: Biloxi
I have aluminum beadlocks with about 4.25oz in each front wheel. I haven't weighed it but I know its heavy. Crawls like a mother and I haven't broken anything. Yet. |
01-20-2014, 11:15 AM | #6 | |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Hope that helps! | |
01-20-2014, 06:34 PM | #7 |
Newbie Join Date: Jan 2014 Location: fallbrook
i purchased G-made sr 02 steel bead lock rims and self adhesive rim weights for 1:1 cars/motorcycles , i ended up ONLY using the sr 02 steel wheels with no holes in the tire or rim with the stock kit foams from the g6 (same tires too) i love having that small bit of neutral air pressure built up in the tire it looks extremely realistic when crawling
01-21-2014, 02:35 AM | #8 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
I normally use the 1/4 ounce weights with the sticky back, but recently I bought some 3/16 Solid Core lead, from Bullet Weights , they only sell it online, the bait and tackle shops, got to order it. cause it is lead based, and the whack jobs in California bitched about it, but anyway, I needed to put two ounces in some Axial 8 hole rims for my 1/16 crawler, normally I use 3 to 3 1/2 ounces per wheel, so I needed to go lighter, and plus the lead was easy wrap around in the center of the rim, then on top of inside of rim inside the tire.
Use stock rims and install lead weights or?? - Similar Threads | ||||
Add-on lead weights. | RC Rocks | Tamiya CR-01 | 2 | 08-18-2012 07:25 AM |
lead wheel weights | dsm4g63punk | Tires and Wheels | 20 | 03-14-2011 09:03 PM |
BB's vs Lead weights | gtbrian | Newbie General | 18 | 09-30-2008 02:12 AM |
lead weights | BASSPROKVD | Tires and Wheels | 4 | 01-05-2008 01:40 PM |
